Tractor Talk Discussion Forum
o/t-motorcycle
Maark
07-29-2006 08:44:27
I have a kawasaki kdx 80 that doesn't have spark. Does someone know how I can test the cdi and coil with an ohm meter to tell if they are bad? Thanks..
dr.sportster
07-29-2006 08:50:55
 Re: o/t-motorcycle in reply to Maark, 07-29-2006 08:44:27
What year?I may have a manual.
Maark
07-29-2006 12:49:26
 Re: o/t-motorcycle in reply to dr.sportster, 07-29-2006 08:50:55
1984, thanks..
dr.sportster
07-29-2006 20:05:42
 Re: o/t-motorcycle in reply to Maark, 07-29-2006 12:49:26
This is from an ealier manual;check ign coil with an ohmeter.Connect the meter to each of the windings primary and secondary in turn.Resistance values in table.Pri coil .21 ohm[+-10%] Secondary coil 1.8 ohm[+-10%] It tells you the color of the wires also.The paragraph on the CDI just tells how it works with no troubleshooting info.These specs may not be correct on your model anyway they are from 76 models.There must be a Kawasaki website where you could get exact 1984 info maybe.Sorry thats all I have.
