Tractor Talk Discussion Forum
Weight of an International 300 Utility?
BTHELD
07-31-2006 14:13:15
I need to know the weight of a International 300 Utility. It is a gas model with a wide front end and filled rear tires.
old
07-31-2006 14:53:29
 Re: Weight of an International 300 Utility? in reply to BTHELD, 07-31-2006 14:13:15
My farm equipment guide has it at 3511LBS but thats with out filled tires so you can add about 600lbs to that for the tires.
TDK
07-31-2006 20:25:39
 Re: Weight of an International 300 Utility? in reply to old, 07-31-2006 14:53:29
We rolled one of ours across scales at 4300 lbs. Had 13.6 X 28 tires(no fluid or weights), fast hitch and T/A. No power steering.
the tractor vet
07-31-2006 18:07:26
That is DRY SHIPPING WEIGHT No fluids at all no battery no gas nothing . Then add for the hitch and other things and it does not take long for the bare tractor to get over 4000-4500 then add the fluids and see where it tips the scales at and if the Cal. is as strong as we make it up here ya can be at 11-11.5 a gallon .
old
07-31-2006 18:22:28
 Re: Weight of an International 300 Utility? in reply to the tractor vet, 07-31-2006 18:07:26
Thats why I posted where it came from so others could add to it. I have/had no idea when they get that weight as far as if its just off the line or if it was ready to run
