Tractor Talk Discussion Forum
How to remove loose, 30-year-old hay from a loft
Blue3992
08-03-2006 14:59:19
I have a large barn with a loft that is covered in old, loose hay. 3 inches in some spots up to a foot in other spots. On top of the hay, there are a lot of old windows, bikes, furniture, and other misc stuff I want to keep.
About the only way I’ve figured I can get the hay out is enlist a couple guys with pitchforks, snow shovels and dust masks and start shoveling. They hay has got 30 years of dust, rotten hay, raccoon droppings, and who-knows-what-else in it, so I was hoping for an alternate solution.
Is there an easy way to get this hay out? Like some sort of truck-mounted vacuum or something?
third party image
third party image
newtothisgame
08-04-2006 19:58:49
 Re: How to remove loose, 30-year-old hay from a lo in reply to Blue3992, 08-03-2006 14:59:19
my dad always said i think to much and here is one of those ocassions not sure if it would work just throwing the idea out there if the hay is matted dow pretty bad and if it is pretty even a thatching blade on a push lawn mower set as high as can go you would have to wet it down this way or a fire would probally happen or if you could lift a self propelled snow blower up to the loft it might also work just one of my hairbrained ideas i came up with
in-too-deep
08-04-2006 16:16:00
If it's possible, back a manure spreader or atleast pick-up or trailer in the barn, cut a hole in the mow floor and drop it right in the spreader or truck. If you can use multiple spots you'll be done before you know it.
RickL
08-04-2006 09:32:19
Simple silage fork/or pitch forks.scoop shovel and face mask. Couples days be done been ther done that but it was almost eight ft deep in most of it,so in your case you don't have much looks to me like.
Billy NY
08-04-2006 07:48:55
You never know what you may find under and in all the old dried out mess,I would definitely wet it down to reduce the dust in the air, not good the breath even the slightest amount of it. That and a good quality dusk mask and it looks like hand work, I cleaned our hay storage area almost 2 years ago, a little nasty dirty work that is for sure, bet you find something interesting in there though, kinda makes it worth doing.
davpal
08-03-2006 23:17:47
Just get some good dust masks and get to it. Sweep it over the edge and push it outside with a blade into the field or haul it to a field and pitch it off. I had to do a barn for a friend that had about 10-15 feet of it in there, loose broken bales. It was a real bitc@! In the bottom level was 3-4 feet (not kidding) of manure and straw mixed that had to be forked and shoveled into a manure spreader by me and spread on a field. It was a huge neglected barn on a homestead he bought from some real old people. He ended up tearing it down and put up a new pole barn there. It sure was a lot of work but I was 15 and had a lot of energy back then! A nice leaf blower will really clean it out good when you are done sweeping. Have fun!
Dave(Tx)
08-03-2006 19:52:03
 Or do it the easy way. in reply to Blue3992, 08-03-2006 14:59:19
Move everything out but the hay. Then run a waterhose to it and soak the hay with water. Now you can sweep/rake it out and no dust no fuss.
Kelly Campbell
08-03-2006 19:38:06
Back a manuere spreader up and let-er rip!
Hal/WA
08-03-2006 18:49:39
At least it doesn't look like there is much chicken or pigeon manure in it! That really makes it bad.
I wouldn't plan on moving it all at once, just do a few square yards at one time, and put the stuff you want to keep where you have cleaned. A garden rake can help dislodge some of it, but most of the work is done with a manure fork and a push broom. A wheelbarrow works great to take that kind of junk to the compost pile.
Always wear a good dust mask. That old hay/straw will bring up allergies you never knew you had. Been there, done that, and it's ugly.
But when you get it all done and cleaned up, you will have the satisfaction of seeing that it looks better and you will probably find a lot of things you didn't remember you had. Good luck and have at it!
paul
08-03-2006 17:08:21
We are renovating my sisters barn for storage. Just did that very thing. 2-4 people with brooms, shovels, etc. Dirty job, but that's how it's done. Leaf blower used as a vaccumn/multcher helped in some spots, but not much.
--->Paul
Chances R
08-03-2006 15:21:55
I had a old barn 50' x 50' x 20' that was full of straw. Attatched to it was a lean 2 that was in good shape. I had a track how pull the barn away from the lean 2 and then dig a big burn pit. I took my 8' grader blade and pushed piles of straw into the burn pit. It was a awfull job, lots of stinking smoke. You couldnt get in a real big hurry because the piles of straw would smother the fire. By the way I did try to give the straw away.
Allan In NE
08-03-2006 15:19:44
Use a potato fork, some elbow grease and a little sweat. Nothin' to it.
Allan
MN Bob
08-03-2006 15:10:15
Man you have a job cut out for you. We renovated an old house that had the old blown in insulation in the walls. I put my sawdust collector outside, ran the hose to a garbage can and put a lid that is sold for that purpose where they sell collector, (ace hardware)ran another hose inside and sucked all the insulation out. Might try something like that. Have to keep emtying the garbage can but sure saved work. Right, wear the mask!
Matt from CT
08-03-2006 15:07:04
I was thinking of vacuum trucks before you even wrote that.
They're used by some septic tank companies, as well as municipalities for storm drain maintenance (remove the muck & sand).
I've also heard of them used for a very similiar application -- removing blown-in insulation after a fire (either the insulation is smouldering, or it's concealing hidden fire still).
Link if you want to buy your own :)
Mattlt
08-04-2006 08:48:37
 Re: How to remove loose, 30-year-old hay from a lo in reply to Matt from CT, 08-03-2006 15:07:04
Agree on the septic vacuum pump truck. We've used them for some attic fires in our area. They work great for sucking out smoldering insulation.
Ray
08-03-2006 15:12:38
I'd say a gallon of gas and some matches.
supergrumpy
08-04-2006 07:49:26
 Re: How to remove loose, 30-year-old hay from a lo in reply to Ray, 08-03-2006 15:12:38
add a case of cold frosty and some lawn chairs
