Tractor Talk Discussion Forum
What did your tractor do today ?
Aowner
09-09-2006 17:56:00
Anybody use their today and what did you do ? I disced up about 30 acres for winter grazing.
Larry W Blum Jr
09-11-2006 09:50:13
 Re: What did your tractor do today ? in reply to Aowner, 09-09-2006 17:56:00
third party image
Hi all,
Friday, 9-8-06, my dad"s Ford 961 got some new decals to go with the new paint we recently put on her. She"s starting to look pretty good.
Charlie in NY
09-11-2006 07:02:40
I replaced the bulb on the worklight and, while I was there, added a booted switch at the base of the housing so I didn't have to use the banana plug as one. Also added plastic washers so it can be gimbaled easier.
The lawn tractor did the work - mowing around the house.
Bud Sather in MT
09-10-2006 18:43:02
I disked up a field where there is going to be a new sub division. Hate to see good farmland going to houses but that is where is money is right now.
Bud
730virgil
09-10-2006 16:07:17
2 of them sat out in rain getting washed . the others inside . 1 of them got washed as roof leaks .
BC-2006
09-10-2006 12:18:20
Mine started for the first time in a year...after restoration. Hand-start...made me tired...I'm going to sleep...
Ultradog MN
09-10-2006 12:16:03
Mine just sat there in the drizzle.
But,
it was joined last night by a parts tractor of the same make and model (Ford 3000) so it is probably impatiently waiting for the new/used power steering and nearly new rear tires it is going to get.
Leon R
09-10-2006 08:11:49
third party image
My three JD are hard at work showing off at the local fall fair for two days. Two will get driven home about 3 miles and the other (MC) will get trailered.
GHT
09-10-2006 05:59:28
Farmall M and wood trailer. Hauled two cords of cherry firewood out. GT
Matt Kane
09-10-2006 05:36:09
I brush hogged the back field, and cut around the garden.
Fawteen
09-10-2006 03:46:05
Hooked her up to the mower and clipped the pastures. If I get the time, she'll get hooked to the bush hog and make one trip around the outside of the fences today.
DCM
09-09-2006 22:17:49
The 8N got paint today and some primer on some parts.All in all a good day.Dan in AB
Mike in Ne
09-09-2006 20:52:38
Mine just sat in the rain.
Gene Davis (GA)
09-09-2006 20:21:46
It just sat there!!!!
Davis In SC
09-09-2006 20:47:22
 Re: What did your tractor do today ? in reply to Gene Davis (GA), 09-09-2006 20:21:46
Mine just sat there with a flat... the tire is rotten... I need to get off my A$$ and get a new one put on it...
Mike (WA)
09-10-2006 09:03:57
 Re: What did your tractor do today ? in reply to Davis In SC, 09-09-2006 20:47:22
Mine was kind enough to just sit quietly and not skin my knuckles up too badly while I twisted wrenches on her.
Gene Davis (GA)
09-09-2006 20:21:28
Don-Wi
09-09-2006 20:14:26
Well, our 1855 sat on the front of the chopper today while I fixed a loose bearing mount on it. The 165 put out a few bales of hay and the 1600 and 285 just sat, just waiting for the chopper to be ready tomorrow.
Donovan from Wisconsin
Gene Davis (GA)
09-09-2006 20:04:32
M Nut
09-09-2006 19:30:21
Worked on building new corals for the cattle this winter. 686 IH on the posthole digger, 830 Case hauling the railroad ties to use as posts on the rear tines, and also used the Case to haul out bales of hay to the cattle, one on the loader and one on the rear tines.
steveiijd4000
09-09-2006 19:25:29
my jd 4000 is being parked. it has only run for sometimes. dont have field any more..
yeah I wishing I had some field to plant sweet corn!
Harold Hubbard
09-09-2006 18:58:34
Took the IH330 and bushogged around a hayfield that didn't get cut, going to string some polywire and turn the neighbor's cattle into it. This afternoon I bushogged a lot for some summer people, got almost finished and the sky opened up, buckets of rain, hail, thunder and lightning. I was pretty well drowned by the time I got home. Got dried off and took a nap, woke up and the power was off, it just came back about half a hour ago.
Craig in MO
09-09-2006 18:56:38
Mine sat there and looked pretty. It's raining this weekend. They needed a rest anyway.
ld5030
09-09-2006 18:56:22
I was a moron and buried my 830 Case in the muck while brush chopping by the cattails.
JDB
09-11-2006 10:34:01
 Re: What did your tractor do today ? in reply to ld5030, 09-09-2006 18:56:22
Picture, we want a picture
BigMarv1085
09-09-2006 18:02:02
I mowed the roads and around the pasture edges with the mf135. Took the 1085 and started discing for my rye and turnip greens. Tomorrow I'm going to push broken limbs around with the 966. Since fuel has gotten cheaper and the weather cooler its time to getter done.
john d
09-09-2006 18:00:27
I put the Super M on an 11' disk and chewed up the cornstalks in my sweet corn patch - roughly one acre. I had fun, and the old tractor did also!
steveormary
09-09-2006 20:38:31
 Re: What did your tractor do today ? in reply to john d, 09-09-2006 18:00:27
john-d
Mine did not do anything. Of course,I dont even have a tractor anymoe. Is your 11 ft. disk a tandem wheel disk? If it is,what gear do you use? We had an 11 ft. disk and a SM and I think we used 3rd gear.
steveormary
Pooh Bear
09-09-2006 18:26:44
I put the dirt scoop on and went down to the river
and scooped up a load of sand/gravel for my Dad.
He plans on pouring a short footing tomorrow.
I been busy with other projects today.
Pooh Bear
juju bead
09-10-2006 07:23:35
 Re: What did your tractor do today ? in reply to Pooh Bear, 09-09-2006 18:26:44
Got the SMTA diesel ready to drive to neighbors antique tractor auction where I have it consigned. Kermit Eide Estate c/o Girard Auction Service. Wakonda SD
