Tractor Talk Discussion Forum
stuck clutch/ Ford 9000
Gunsmoke
09-18-2006 12:47:25
I purchased a Ford 9000 with dual power that had been parked in working order and left to sit for 7 years. The parking break was stuck, engine was lightly stuck both of which I now have working well.
In netral the tractor starts and runs but after depressing the clutch the gears are still spining. I have started it in gear and it will drive in that gear but the clutch will not dissengage. The peddal has good tension and I adjusted all the travial out to apply the most preturn force possiable.
I have run it for several miles to get it heated up and pushed in the clutch the whole time along with hitting the breaks repeditly, still engaged. I then hooked to a field cultivator and set it deep pulling the engine hard with the clutch peddal depressed most of the time. 2 hours later and I have a worked up field but the clutch is still engaged. There are no inspection covers on this tractor and spliting it would be to big a task yet this fall.
Dose any one have any sugestions on what you have done for this situation? Also what is your opinion of the 9000, what are its problem areas?
jake4
09-19-2006 17:51:39
 Re: stuck clutch/ Ford 9000 in reply to Gunsmoke, 09-18-2006 12:47:25
Fords are great with this problem, the disc rusts to the flywheel or clutch. I take a C clamp to hold the clutch pedle down, put in gear and pull with another tractor. Gear chosen might have to be changed, I use 1st gear, works every time. LOL
Kevin (FL)
09-19-2006 16:43:30
Gunsmoke,
I knew an old timer that would fill the bell housing with diesel whenever he ran across your problem. I never heard him say that he couldn"t find a way to get the oil in though--maybe he had to drill a hole in the top of the bell housing or something. But I remember he said it always loosened the clutch spline from the shaft. He would let it soak for a couple of days with a pan underneath to catch any spillage and work the clutch pedal in and out whenever he had the time.
Gunsmoke
09-20-2006 13:59:44
 Re: stuck clutch/ Ford 9000 in reply to Kevin (FL), 09-19-2006 16:43:30
I have always been told that a dry clutch cant have any form of lubercation on it or it will scip and tsart breaking apart.
I will try this idea anyhow becouse the worst case is spliting the tractor and thats what im faced with now.
Kevin (FL)
09-20-2006 18:32:18
 Re: stuck clutch/ Ford 9000 in reply to Gunsmoke, 09-20-2006 13:59:44
Gunsmoke,
The fellow that told me this was a tractor and heavy equipment mechanic for over 40 years. I don't remember him saying that he used degreaser after the fact but would assume that wouldn't hurt. Maybe do a wash-out with mineral spirits to clean off the diesel. But the way I see it, using the pressure plate & clutch will eventually dry it out, but I know regular motor oil will end up glazing on a clutch disc. I'd say give the diesel a try before you have to split her in two...
RickB
09-19-2006 15:30:41
Sounds like the biggest problem area with yours is the clutch. With what you have done (without success) to unstick the clutch, plan on splitting it.
