Tractor Talk Discussion Forum
Re: NEED ALTERNATOR WIRING DIAGRAM
John T
09-20-2006 09:33:02
Ronald, Bob usually posts his nice picture to answer your question while Bob M has a great wiring diagram n Old n myself n others describe it for you IFFFFF F youre planning to use the GM 10 SI 3 wire alternator wired to work like a one wire, and they, like most alternators, REQUIRE NEGATIVE GROUND. The One Wires can require a higher RPM to excite while some (depends on internal regulator used) cause a very small trickle discharge, so due the the low cost and easy availability I prefer the GM 10 SI wired as described below. NOTE mine and Bob n Bob M's n Old's methods are slightly different and both work fine, I just prefer to use the current limiting 10 ohm resistor (might protect the diodes) versus a diode and in most cases the diode isnt even required when it or an idiot light is used in the excitation circuit.
The tractor MUST be used at Negative ground and heres how I describe wiring them. Bob M’s great diagrams puts it in pictures, which they say is worth a thousand words, so take a look and see for yourself.
Heres how I wire a GM 10SI Alternator and remember, it requires NEGATIVE GROUND !!!!! !
The big rear main alternator output terminal goes to the wire that used to be connected to the BAT terminal on the Voltage Regulator or Cutout Relay. HOWEVER if that wire wasnt already upgraded, when I convert from a Genny to an Alternator, I replace that wire with a 10 Gauge and it runs from the alternators main output up to the LOAD (NOT to battery/starter) side of the ammeter. I also replace/use 10 Gauge from the ammeters other SUPPLY terminal to the battery/starter.
The little side number 2F Voltage Sense Terminal gets connected (use a short 14 jumper wire) right up to to and with the big main output terminal mentioned above.
For the little 1R side Excitation Terminal, run a 16 or so gauge wire from the ignition switches IGN (which is HOT ONLY when ignition is turned on) terminal and in series with it place a 10 ohm 5 watt current limiting protection resistor (dont really need that much wattage power rating, but they are heavy duty built and easy to wire). Then in the rare event the tractor continues to run cuz of alternator backfeed when the ignition is switched OFF, I add in series a 5 amp 50 PIV minimum Diode. The diode must be wired with negative cathode end to the alternator and positive anode end to the switch. Again, the ratings are not that exact but about any diode over a few amps and 50 volts or so works.
Dont forget to change the battery to negative ground and the coil needs to be wired so the negative goes to ground via the distributor points and the positive gets power from the ignition switch and you have to reverse ammeter leads also if your just now changing polarities.
Good luck Ol John T in Indiana
Ronald Deschamps
09-21-2006 05:37:26
 Re: NEED ALTERNATOR WIRING DIAGRAM in reply to John T, 09-20-2006 09:33:02
Thanks very much for the info and the pictures. They are just what I was looking for. Forgot to mention the tractor is a diesel if it makes any difference . Ron
John M
09-20-2006 14:56:09
Not that Im doughting you, but why would you connect the output wire to the VR. I have three tractors with the 10SI on it and not one of them have a regulator.
John M....Sorry
09-20-2006 15:13:59
 Re: NEED ALTERNATOR WIRING DIAGRAM in reply to John M, 09-20-2006 14:56:09
Brain is a little fried this afternoon! Had to reread it again.
Bob
09-20-2006 12:34:09
 Trying the link again... in reply to John T, 09-20-2006 09:33:02
Here's the photo.... and a link to BobM's diagrams.
Third Party Image
The diode shown in the photo, or the "idiot light" shown in BobM's diagrams are directly and completely interchangeable with each other.
If you want an "idiot light" in the dashboard, use the "lamp" option, if you DON'T want the light, use the diode, as shown.
Link
Bob
09-20-2006 12:32:45
 Good Afternoon, JohnT! in reply to John T, 09-20-2006 09:33:02
Third Party Image
http://albums.photo.epson.com/j/AlbumIndex?u=4001561&a=30065733&f=
