Tractor Talk Discussion Forum
Still having fuel problems
Dug
09-20-2006 19:12:47
I posted last week about air entering the fuel system on my JD F935 mower. I put new fuel lines on thinking one may have been cracked, but it seems there is more air entering the system now...when I turn the fuel pump on to bleed the system, I can not purge the system of air. Loose clamp, maybe? Could the fuel line inside the tank be damaged? What stumps me, besides mechanics in general ; -), this is happening on both fuel tanks. Any other suggestions before I load her up and head to the dealer (and the bank to take out a loan to pay the dealer...)
tcwinkc
09-21-2006 03:19:44
 Re: Still having fuel problems in reply to Dug, 09-20-2006 19:12:47
I would look at fuel return hoses.The problem you describe of sucking air is typical of that era yanmar.In that it is a closed system this is the area of most concern,also due to engine heat hose becomes dry and does not seal as well. I agree with earlier post as to pressure checking fuel system. Sometimes though you still may not visually identify problem. It is not a bad idea to replace those return hoses anyway it might cost all of five dollars.The only other area to check would be filter.I have seen small cracks in the casting of filter head when tightend just a little too much, it happens. Good luck.
huntingreen
09-20-2006 20:35:45
How about a hole in the pump diaphram? Pickup tube in the tank?
Dug
09-20-2006 20:50:27
 Re: Still having fuel problems in reply to huntingreen, 09-20-2006 20:35:45
I wondered about the tube in the tank, but what are the chances of both tanks having an issue? May pull the tanks and replace the fuel lines inside...the fun continues...
Bob
09-20-2006 21:02:26
 Re: Still having fuel problems in reply to Dug, 09-20-2006 20:50:27
You think the "dip tubes" in those little tanks are fun... the big 4-wheelers, 8630's and 8640's, etc., used to have trouble with the dip tubes in their big RH saddle tanks clogging or breaking off in the 80-to-100 gallon steel tanks. Now THAT was a LOT of tank to mess with!
Janicholson
09-20-2006 19:57:32
I recommend using pressure to find the leak. Temporarily plug the vent in the cap with gorilla tape (or duct) then use a tire pump (not a compressor) to put modest pressure into the line at the other side of the filter. If fuel does not come out making the leak obvious, use a spray bottle of dish soap and water to spray down the system looking for leaks. JimN
Dug
09-20-2006 20:06:59
 Re: Still having fuel problems in reply to Janicholson, 09-20-2006 19:57:32
Great idea! But, how do I connect the tire pump to get an air tight seal? Could I seal the fuel line with vise grips and insert a sports needle into the fuel line?
Bob
09-20-2006 19:28:19
Apparently, you have an electric fuel pump. Are you aware they can fail, and not pump fuel, or not have enough pressure, even though you hear them "running".
Any chance that could be your problem?
Dug
09-20-2006 19:37:28
 Re: Still having fuel problems in reply to Bob, 09-20-2006 19:28:19
I changed the fuel pump last spring when this problem started on the right tank. Then I realized the left tank worked fine and spent the summer mowing with just the left tank.
Bob
09-20-2006 19:44:45
 Re: Still having fuel problems in reply to Dug, 09-20-2006 19:37:28
So.... there's a valve to select which tank it draws from? Electic or manual?
Dug
09-20-2006 19:58:32
 Re: Still having fuel problems in reply to Bob, 09-20-2006 19:44:45
Manual.
Jay (ND)
09-20-2006 19:22:40
Spin on fuel filter? On my truck, I have to do more than hand tighten, otherwise I drop prime.
I would try tighten an extra 1/2 turn.
Also, does this have plastic lines that snap into place?
Jay
Dug
09-20-2006 19:32:19
 Re: Still having fuel problems in reply to Jay (ND), 09-20-2006 19:22:40
The fuel filter is "in line"..
Fuel hoses were clamped on with spring claps, I changed to screw hose clamps to get a snugger fit.
This thing has be baffled...shouldn't be this difficult. The leak has to be on the tank side of the fuel pump. With new lines, what else could be wrong?
jmixigo
09-20-2006 19:21:15
After all that purgin an bleedin an cussin an line changin an more cussin..... ..
how much feul ya got left in there?
This is the kinda thing I forget so I just asked.
Dug
09-20-2006 19:33:28
 Re: Still having fuel problems in reply to jmixigo, 09-20-2006 19:21:15
One tank is full and the other is just over half. But, I wouldn't admit it if the tanks were empty...; -)
