Tractor Talk Discussion Forum
6V Pos. Ground Alt UPDATE
Bob Naske
09-21-2006 08:08:43
Previous post on alt installed on JD LA that wasn't charging has been solved. The general concensus was that it wasn't spinning fast enough as the alt had standard 2 1/2" pulley on it and LA's don't run at much above idle by todays standards. I put a 1 3/4" diameter pulley on as that was the smallest I could find locally. Start tractor, briefly accelerate to close to max engine rpm & alternator energizes itself & charges at 10-20 amps even at idle until batt charged back up.. So thanks to all that responded and helped solve it!
old
09-21-2006 09:08:45
 Re: 6V Pos. Ground Alt UPDATE in reply to Bob Naske, 09-21-2006 08:08:43
Now you know why the 1 wire alternators cause so much trouble, alternators like RPM to get them to kick in and tractors just don't have the RPMs
