Tractor Talk Discussion Forum
OT Engine Swap Flathead Jeep/Welder
Uncle
10-12-2006 19:58:04
I have an older Hobart welder that is powered by a 4 cly flathead Jeep. Can anyone tell me what engine will have the same bellhousing bolt pattern. I want to go to newer powerplant.
Brian
RN
10-13-2006 14:20:13
 Re: OT Engine Swap Flathead Jeep/Welder in reply to Uncle, 10-12-2006 19:58:04
Flathead Jeep? If it is the Willys flathead-Go devil -engine then the later F head Hurricane from CJ3-5 will bolt up- about 10 more horsepower. If a Ford Jeep engine? Not sure, had a few show up at jeep dealer I worked at, didn't see any magor difference in mounting of engine. RN
Ultradog MN
10-13-2006 04:53:58
Uncle,
there was a standard SAE bolt/bell pattern that they came up with in WW2. There are probably several engines that would fit - Continental, Jeep, Chrysler, Hercules, Buda etc.
Roy Suomi
10-12-2006 20:22:40
Why in the world would you change that sweet running engine??? I've got one on my F-600 service truck..I air-arc with it .I thaw water lines with it..Sometimes I even weld with it..It's easy and cheap to rebuild..I stuck a nice muffler on it so it's not too loud..I've got my Hobart on a roller type of deal in a channel frame. I can pull it almost all the way out to service it..It's slick..
37 chief
10-12-2006 20:18:29
I think the early scout engines will bolt up. I also think an adapter for any propular engine is being made. You may want to look on a four wheel sight for the info. on where to find it. Stan
KEB
10-12-2006 20:15:11
Ask on the www.willystech.com forums (I think you have to register). Bunch of people have done engine swaps into old jeeps, someone should know what does & does not bolt up.
Keith
