Tractor Talk Discussion Forum
Farmall Cub
Lee Christianso
12-14-2006 11:44:26
Looking for info re: value of this tractor. It's a bit unique. In 1947 my father bought the first rubber-tired Cub made. Part of the deal was that he was to allow IH to take pictures of him using the Cub for promotions. My mother has the pictures somewhere and I've seen a few. The tractor is still in the family, still runs and looks good. It's all original except for a few wires and is wearing only the second set of tires. My mother gave it to me when my father died and I"ve given it to my son. He's been wondering what kind of value it may have. Many thanks for any info...
robert owens
02-15-2007 19:20:15
 Re: Farmall Cub in reply to Lee Christianson, 12-14-2006 11:44:26
Don't think the cub ever came on steel wheels either, I have a 53 model, with serial number code J, what doe's anybody know what the J mean's?
Lee Christianson
12-15-2006 07:45:24
I always wondered about that too (1st rubber tired Cub) since I never saw any on steel either. Maybe it's my feeble memory but I am fairly certain he stated it that way. IIRC even the F-series were on rubber and the steel stuff was the 10-20 and 15-30...
I'm betting that he meant it was the first in this area. I'll have to wait until the weekend to get a pix that's decent. I have to move a truck and trailer to get at it and take it outside. Flash pix do not do it justice.. I'll try to find the engine number also although I know it's the original. It was overhauled in about 1960 and hasn't been worked a lot since. I used it for cultivating vegetable crops on 20 acres from 1972-1980. It's been nearly unused afterward.
I really appreciate the replies from all of you. Many thanks.
Hugh MacKay
12-14-2006 18:02:03
Lee: Someone is pulling your leg, there never were any Cubs on steel. Cub production didn't start until 47 or 48. Almost no tractors were on steel by then.
There were some A tractors on steel, but I don't think it was an IH option. At least the ones I've seen were not IH. They were fabricated by an independant shop. Any wheels that bolt up to A wheels will bolt up to Cub wheels
Midwest redneck
12-14-2006 14:14:37
In my area of Michigan a guy was selling a Cub for $3,500 (that was the asking price) on the side of the road. It was gone in 2 weeks. It looked like new paint and looked to be in good condition.
banjo
12-14-2006 13:51:53
not an expert by no means.I know there are educated folks on this board but farmall.com will have lots more info on a cub. Jim Becker seems to know a lot of the small details.
Bus Driver
12-14-2006 12:21:44
Officially, the first Cub was serial number 501. A person claiming to have that tractor has long ago and widely publicized that claim. What is the serial number of your Cub? The engine serial is stamped on the engine block behind and slightly to the rear of the carburetor. What is that number? The major castings have dates codes cast into them. The end of the code is a letter. Post some of those codes.
Lee Christianson
12-14-2006 13:23:47
 Re: Farmall Cub in reply to Bus Driver, 12-14-2006 12:21:44
There"s a plate just aft of the radiator, on the RH side of the engine that has, "serial number" (then the numbers) 1784.
If 501 was the first, then maybe he meant "first year of production", or "first one in this area", or similar. The pix are definately from the IH people who used them for advertising the tractor.
Does this give you enough info?
Bus Driver
12-14-2006 17:41:42
 Re: Farmall Cub in reply to Lee Christianson, 12-14-2006 13:23:47
1784 is definitely early production, possibly the first one delivered to that particular dealer. The engine serial number might match the tractor, but probably is a few numbers higher. The engine numbers went higher faster than the tractor serial numbers due to engines being held for replacement purposes and other uses. Any engine serial number lower than the tractor serial means that some parts swapping has occurred after the tractor was new.
Kevin (FL)
12-14-2006 12:13:59
Lee,
First--I"ll say that I wouldn"t consider myself a Cub expert, but we do have six or seven around here plus a few spare engines and misc. parts. As far as I know there weren"t any steel wheeled Cubs--I believe they always came with rubber. As for promotional Cubs--I believe they were called Demo Cubs and they were painted white. Those bring a higher price than the "everyday" Cub. Running Cubs bring anything from $1200-$3000 depending on condition and implements included with the deal. There"s probably been a few sold at $3500 and more but not on a regular basis. If you post some photos and provide a serial number we can confirm the year model and maybe provide more info. Also you can post on the Farmall page and there"s a dedicated web site out there for the Cubs too.
Lee Christianson
12-14-2006 13:29:40
 Re: Farmall Cub in reply to Kevin (FL), 12-14-2006 12:13:59
I will try to take some pix and post them. I know he had a bunch of equipment for this tractor, because I used most of it myself as a kid. He had a one-row mounted plow, the disk, the cultivator (still have that) and a side-mount sickle mower. I haven't seen that for a few decades but I think it was about a 4-5' swath. He had me mow Canada thistles with it in some soil bank fields at the home farm. Also had the belt pulley, not sure if there were any other attachments.
I had the clutch repaired a few years ago and the radiator repaired.
Engine runs well with no oil usage. Starts easily with the crank. Starter works I think but we've not put a battery in it for decades..
Dennis in NC
12-14-2006 13:10:40
KEVIN I THINK YOU ARE RIGHT ON , NEAVER HEARD OF A CUB ON STEEL
Cue P.
12-14-2006 14:33:21
 Re: Farmall Cub in reply to Dennis in NC, 12-14-2006 13:10:40
I agree. Thats the first thing that caught my eye. Not even the A came on steel - which some might confuse as a cub - as far as i know. Now if they said a model H or something then that would make sense.
old art
12-14-2006 19:12:45
 Re: Farmall Cub in reply to Cue P., 12-14-2006 14:33:21
the first line of his post. said his fathers first RUBBER TIRED TRACTOR not steel that the way i read it .
Keith-OR
12-14-2006 19:20:19
 Re: Farmall Cub in reply to old art , 12-14-2006 19:12:45
Art....Quote from Cue P... "In 1947 my father bought the first rubber-tired Cub made".
Keith & Shawn
