Tractor Talk Discussion Forum
IHC 684 power beyond Kontak valve
684 RED
12-26-2006 13:14:32
I own a IHC 684 about a 1980 model that I have put a Bush-Hog front-end loader on. I am using the remote at present with the lever tied down as the loader is equiped with a joystick. Now for the problem I want to put on a power beyond but have found out that the tractor has a Kontak remote valve, does anyone know where I can obtain a power beyond for a Kontak valve? IHC power beyond won"t bolt up to this. thanks for any help
richard in nz
12-26-2006 23:02:53
 Re: IHC 684 power beyond Kontak valve in reply to 684 RED, 12-26-2006 13:14:32
Kontak was the standard remote that came on those tractors from the factory, you should be able to get them from Case-IH. If not I have in the past drilled and tapped a piece of steel plate 3/8" BSP for the supply and 1/2"BSP for the return, fitted this in place of the existing end plate, and hooked up the new remote that way for loader work. If you remove the end plate you will see where the ports have to be. I am fairly certain you can still get those end plates, have you tried a good hydraulic specalist?
