Tractor Talk Discussion Forum
ripped the clutch clean out while running
HAPPY DEERE
01-05-2007 09:39:48
im about ready to cry my pulling tractor i am building finally got soem work when the old fordicator got stuck in the mud bringing the disk out of the field so i went and got my old 51 a jd. i hooked it to the front of the ford gave it about 3/4 throttle and put it in first AND EASED IN THE CLUTCH NEXT THING I KNOW IN ABOUT FIVE FEET LATER MY TRACTOR STOPS CLUTCH STILL SPINNING AND THEN THE COVER COMES OFF AND THREE OF THE ENDS OFF THE ADJUSTMENT BOLTS CAME OUT ALONG WITH THE PRESSURE PLATE AND THE FIBER DISK IN THE FRONT THEN IT STARTS GRINDING AND CLANKING NOW I QUESS I NEED A NEW CLUTCH INTIRELY AS THIS ONE COMPLETELY BLOWED OFF IM JUST GLAD I DIDNT GET HURT
HAPPY DEERE
01-07-2007 09:51:44
 Re: ripped the clutch clean out while running in reply to HAPPY DEERE, 01-05-2007 09:39:48
ok if i learn how to post pictures i will on here as of now it has been tooken all apart look like it broke a few teeth off of the gear in the back (((dont know where they are))) and put itself in the bind under the load so i found a buddy of mine up the road that has a all new clutch assembly for it.
kyhayman
01-05-2007 19:49:28
I ripped the center out of one on a 7710 Ford a few years back. Spooling up with the disc mower, and boom, center disc rivets ripped out.
Walt Davies
01-05-2007 18:14:01
More years ago than I want to admit I was at the San Diego drag-strip when a small dragster blew his clutch. In those days we just stood right on the track and as close as we could get to the car that was running. There parts of clutch laying all around me and I watched the flagman who was out front drop to his knees, he was hit right between the eyes with a large chunk.
Boy those were the days.
They finally had to close down that old strip because the fast cars were going of the end and out into the freeway. Walt
CLW
01-05-2007 12:08:11
Look at it this way, it could have happened on the track with lots of people looking on.
chiefrunamuk
01-05-2007 11:15:57
HAPPY DEERE; Dont feel to bad, had a brand new 1954 chevy one ton loaded with beans, down shifted from 4th to third to go around a corner, high pitched scream, lookie here clutch and pressure plate scattered all over the pavement;less than a thousand miles on the truck. Chevrolet co. was not to pleased. Ken
Walt Davies
01-05-2007 10:41:53
DANG you ot to knowed better than to pull a Ferd with one of those Ugly Green things. Just kidding.
You need to remove everything and look at what other damage you did under there. the flywheel bolt holes are pretty much gone too.
Walt
Glen in TX
01-05-2007 10:33:31
Yeah glad no flying parts hit anything. Hope the bronze fork or other parts didn't break. Pull the clutch brake out and clutch pulley off too to make sure and check for more wear on that and toggles in back side and regrease or replace the pulley bearing.
Stumpalump
01-05-2007 10:33:05
Now thats quality breakage! Glad your OK.
Here's another sinario when a clutch will disinigrate. If you are in a very low range and push the clutch in and let it roll fast downhill the gear reduction becomes gear multiplication on the clutch. The clutch can see 15000 rpm and explode. This happens a lot on 4X4 trucks when I guy eases over the top of a hill and then pushes in the clutch to let the vehicle run out at the bottom. Be the same effect with the low gears on a tractor so watch that clutch on the down hills.
Randy as in Randy-IA
01-05-2007 16:06:50
 Re: ripped the clutch clean out while running in reply to Stumpalump, 01-05-2007 10:33:05
Years ago my younger brother was racing a '70 Nova at the racetrack in east St.louis area and did a 7000 rpm launch . The flywheel came apart and came up through the firewall and missed his right foot by not even an inch . Then it continued on up through the dash and pushed the rear part of the hood up 10 inchs and stuck there . The piece weighed about three pounds . The rest of it buried itself in other parts of the car and the asphalt track . Obviously the car was trashed and was taken to the junkyard . The motor was destoyed by the overreving after the flywheel came apart . It wasn't fun for him or the track officials . That was before scattershields were made manditory for that class . ...Randy
dhermesc
01-05-2007 11:12:48
I'd never heard of that but it makes a lot of sense.
