Tractor Talk Discussion Forum
Hyd hose diameter question
old
01-06-2007 15:56:31
With all things being equal, same GPM and same PSI. Is there any advantage useing larger size hoses. I have one tractor that uses 1/4 inch hose and I'm thinking about going to 3/8 or 1/2 inch. Is my thinking right that it will do nothing out then hold a small amount more fluid in the system?? What do you guys think.
Thanks.
Reason I'm thinking about the bigger hose is that I have it laying around but don't have much of the 1/4 inch stuff and have been digging out of my scrap stuff to find enough for what I'm doing
Paul Janke
01-07-2007 07:16:35
 Re: Hyd hose diameter question in reply to old, 01-06-2007 15:56:31
Allis Chalmers is a piston pump, and runs high pressure. Others will know, but I think it is 3600 PSI. Make sure your hoses will take that.
Jerry/MT
01-06-2007 19:00:08
Using a larger hose will give you a little more pressure for given flow at the business end of the hydraulics and means you'll have a tad more oil to add. (The reason is that the pressure loss is proportional to the flow velocity squared and the velocity at a given gpm ~ 1/Area so increasing the area reduces the velocity which reduces the pressure loss.) You'll loose a little of that pressure if you have to go back through a smaller area fitting.
Midwest redneck
01-06-2007 16:09:09
1/4" hose will (can be) used at a higher pressure, check the rating on the hose itself. A 3/8" line will allow the fluid to not travel as fast in the hose as the fluid is moving. Fluid velocity in piping is as follows: .3208 X gpm/IA (IA = internal area of the hose. (this is ft/sec) SOoooo. A 3/8" line will be better then a 1/4" if it is rated for the pressure. Fluid velocity should not be more then 30ft per second. If the fluid is traveling faster then 30ft/sec in most cases the fluid will become turbulent in the line and heat up too much. BTW----I am a hydraulic systems tech/builder. One way to determine line size is the pipe port on the cylinder or valve that it is going to.
old
01-06-2007 16:30:08
 Re: Hyd hose diameter question in reply to Midwest redneck, 01-06-2007 16:09:09
This is on an Allis C and the cylinder inlets are 1/4 and I plan to adapt up to the 3/8 or 1/2 inch hose just because I have the hoses laying around. I figure I can get the adpators for about 1/4 of what it cost to have an 18inch hose in 1/4 made, so I'm just tring to save money since I don't have much to play with right now
Midwest redneck
01-06-2007 16:33:14
 Re: Hyd hose diameter question in reply to old, 01-06-2007 16:30:08
Sounds good to me. Saving a buck or 2 is always a good thing.
