Tractor Talk Discussion Forum
1960 cat grader
Finn
01-08-2007 07:11:26
I have a 1960 Cat 12 grader with a gas pony motor. When I start the pony it rev's up good, but when I put it under load it will pop and stall out. I have to kick it back off load and hit it again, and again it will lug down. I have changed spark plugs, drained the cylinders,but have to mess with it for a while befor I can get the diesel going. Has anyone got any ideas. Thanks
Leland
01-08-2007 20:45:52
 Re: 1960 cat grader in reply to Finn, 01-08-2007 07:11:26
pour some seafoam in the gas and see if it runs better ,let it run until it's out of gas to let the seafoam do it's job .
old
01-08-2007 09:30:35
I'm like Rusty I have never messed with a pony engine before but all engines work the same way. From what you say its either just plain getting weak and probably has poor compression, or you have a carb problem and its running way to lean which also means its not produceing the HP that it should be.
Steve Masterman
01-08-2007 08:12:42
ive got a d8 did same thing. carb was dirty from sitting with old gas.best to shut gas off and let pony run out after diesel is started.takepony carb apart blast allpassages with carb cleaner and air reassemble anddont worry about it for another 20 yrs steve
RustyFarmall
01-08-2007 07:25:29
I have no experience with those pony motors, but it sounds like you are experiencing either ignition problems, fuel delivery problems, or both. My first thought is a dirty carburetor, but a weak ignition coil will exhibit the same symptoms. You have replaced the spark plugs, what about the spark plug wires? and the ignition coil wire?
Finn
01-08-2007 18:04:47
 Re: 1960 cat grader in reply to RustyFarmall, 01-08-2007 07:25:29
Thanks for the ideas. I am going to pull the carb off tomorrow. Thanks again
