Tractor Talk Discussion Forum
Grease marker removal
Eli
02-02-2007 18:15:54
Can anyone tell me how to remove the white grease marker the auction guys write all over sold items. I tried lots of stuff even laquer thinner. No luck. Thank you, Erick.
Randy as in Randy-IA
02-04-2007 11:27:42
 Re: Grease marker removal in reply to Eli, 02-02-2007 18:15:54
Acetone ( fingernail polish remover ) or if you are a painter of tractors use zylol ( I don't know it's generic name ), if those don't work then denatured alcohol or adhesive remover ( this might be acetone ) . Or I'd just keep scubbing it with a scotchbrite pad and dawn dishwashing liquid and HOT water . If that doesn't work I'd move onto a polishing cream for paint such as a medium rubbing compound . Last ditch effert - break out the heat gun and warm it up good and then try the polishing compound again . Some things just can't be removed though without finding bare metal so good luck ! ...Randy
JCSinGA
02-03-2007 12:42:58
I purchase cars and trucks from auction from time to time. They always write on the windshield or some glass. I use a single edge razor blade scraper to get the most off then some fine steel wool to get the rest.
Vern-MI
02-03-2007 04:54:49
If it is truly a white wax like crayon then use Mr. Clean Magic Erasers. If it is one of those dry markers then try alchol.
doogdoog
02-02-2007 23:38:57
Aloha, Don"t know what the marker is made of but you could try lighter fluid.
Mahalo,
doogdoog
msb
02-02-2007 18:25:21
Try Goof Of or Goo Gone.Available at Wally World and other fine stores.lol.
