Tractor Talk Discussion Forum
656 hydraulic problem
IH656 In KY
02-25-2007 14:19:09
Hi,I am new to the forum.
I have a 656 diesel standard trans with 6000 hrs.The only way I can get the lift to go up is to work the aux hyd handle.The pump will make some noise and the lift goes up.Also the power steering will not work when its cold.The oil level is fine.Any help would be greatly appreciated.
Allan In NE
02-25-2007 16:04:15
 Re: 656 hydraulic problem in reply to IH656 In KY, 02-25-2007 14:19:09
First thing I'd do is change that hydraulic filter and she how things are at that point.
Since both pumps pull thru the same filter, this might possibly be a cure for both of your problems as the hitch is at the bottom of the food chain in that tractor and the power steering is the first to show problems when the system tries to bypass cold.
If you still have to use full system pressure to raise that hitch, I'd really be suspect of your hitch pump.
Hope ya get 'er,
Allan
IH656 in KY
02-25-2007 17:39:11
 Re: 656 hydraulic problem in reply to Allan In NE, 02-25-2007 16:04:15
Thanks I will try that.And post the results.
