Tractor Talk Discussion Forum
1940 allis chalmers b narrow front ?
1234
03-02-2007 15:51:04
can any one tell me. i just purchased a 1940 allis chalmers b narrow front end. serial #44644. did they even make a narrow front end model b. just want to know if the tractor was described right on auction. thanks
old
03-02-2007 17:06:21
 Re: 1940 allis chalmers b narrow front ? in reply to 1234, 03-02-2007 15:51:04
From what I have been told over the years there never was a B made with a trike front end. What it most like is, is a mutt tractor where some one took 2 or 3 tractors and made one out of it. Its probably got a C front end one it or it could even be a C since thay look very much alike but the C has a wide rear end then the B does but the engine and tranny is the same just a differant rear end on them
D13
03-03-2007 04:47:28
 Re: 1940 allis chalmers b narrow front ? in reply to old, 03-02-2007 17:06:21
A couple of years ago Dick L had a B trike that looked original, when he got it all torn down he found that it had been swapped with C parts a long time ago.
Compounding the question is the use of C style bolt-on hubs on the backs of some B's, and the availability of adjustable wide fronts on B's.
One of my B's has a BE engine with a B torque tube, one has a CE engine with a CA torque tube (extra mounting pads on the side), the other has a CR combine engine from an All-Crop with a CA tube. When I sold my C I swapped the wide front from a B including the steering box ont it.
D13
03-02-2007 16:40:47
It's a C front end. Bet the rear steering arem points up. Either a C wit ha B trans or a b that they replaced the front and steering on.
Graham of NZ
03-02-2007 16:38:20
Most ACs here came at the end of WW2. Only two in our area were B and WC. Both had narrow front ends. (Pedestal with wheel each side)
