Tractor Talk Discussion Forum
diesel injection lines
cb in wisc
03-12-2007 12:53:46
What can you use or what is the best thread sealer
to use on the connections on the diesel injection
lines?
RAB
03-12-2007 16:13:45
 Re: diesel injection lines in reply to cb in wisc, 03-12-2007 12:53:46
Threads don"t seal, ever, on diesel injection lines. The only sealant is metal to metal contact.
RAB
Hurst
03-12-2007 16:10:16
Nothing, just a good bit of torque. Are they leaking? If so, the nipple fittings are either not matched correctly or are damaged. Check those out. Also check out the the return line, they use copper washers or gaskets in most cases, and they can leak from a bad gasket or washer. Do not use any type of sealer that can get into the injector, the tolerances are too tight and you could ruin an injector if something gets in there.
Hurst
Bob
03-12-2007 12:56:51
Never heard of using (or NEEDing) sealant on injection lines. What'cha work'in with?
cb in wisc
03-12-2007 16:21:51
 Re: diesel injection lines in reply to Bob, 03-12-2007 12:56:51
I have a Oliver 1650 diesel and the lines for three injectors are weeping by.
msb
03-12-2007 18:15:31
 Re: diesel injection lines in reply to cb in wisc, 03-12-2007 16:21:51
You will have much better luck getting connections to seal if you first wash all parts in a fast drying paint thinner like PT 160 from Deere. The thinner washes off all traces of fuel that attract dust and dirt floating in the air which causes most leaks.Just blow everything dry before assembly. Then if you look closely at the washers, you will see they are slightly convex from when they were stamped out. Install the cup side towards the line like this----- -H (8)H.Then be sure the lines are not tightened under stress or vibraion will back the fitting back loose after the engine has run for a while.
