Tractor Talk Discussion Forum
Chevy 4x4 Actuator
Tweeter
03-31-2007 11:51:39
I replaced the 4WD actuator on my 1988 K2500 truck but do not know where the brown wire on the new harness splices in at. The is a plug on the back driver side of the transfer case with two wires (yellow/black, purple) screws in parallel with the ground. There is another plug in the driver side transmission behind the front drive shaft that has a square plug end that mounts vertically. Which is the right one?
dyt4000
04-02-2007 02:51:15
 Re: Chevy 4x4 Actuator in reply to Tweeter, 03-31-2007 11:51:39
Link
howeduin
03-31-2007 19:17:07
the wire on the t\case is also brown
should be on drivers side near top of
t\case
Bob
03-31-2007 12:15:06
The wire is connected to a switch on the driver's side; up high; on the transfer case.
Brown wire; will have power only when ignition is "ON". 4X4 lever position has NO effect on whether that particular wire has power; or not; just the ignition switch.
Post back; if you don't figure it out.
Tweeter
03-31-2007 13:09:02
 Re: Chevy 4x4 Actuator in reply to Bob, 03-31-2007 12:15:06
The only one I see is on the driver side near near the very back where the rear driveshaft connects. It is screwed into the housing under near a round red and stainless tag riveted to the transfer case housing. Is the wire on the truck also brown? The wire on the new harness is brown.
Bob
03-31-2007 13:14:38
 Re: Chevy 4x4 Actuator in reply to Tweeter, 03-31-2007 13:09:02
I'm almost certain the wire on the truck is brown; too. It's been a while; and I can't tell you any more from memory.
If you can wait day or so; I'll post a photo.
Bob
Tweeter
03-31-2007 13:31:25
 Re: Chevy 4x4 Actuator in reply to Bob, 03-31-2007 13:14:38
The photo would be great. Thanks.
