Tractor Talk Discussion Forum
bale forks for loader
DJL
04-10-2007 20:22:41
I need a set of bale forks for the loader I've been yacking about on this forum today. I want the type that pin to the loader versus the type that clamp to the bucket. A few years ago, dad had a bale fork on the front of an IH 2250 loader that was made by I believe "Double L". I really liked these forks because the forks were positioned towards the bottom of the bracket and were beefy, unlike the bale spears I've seen around recently. They were great in my perspective because you could use them for other things like fence posts, brush, poles etc, like you can the 3 point bale forks. Im my search, I'm finding alot of bale spears but not forks. Any ideas? What do you guys use?
Thanks
JMS/MN
04-11-2007 13:02:59
 Re: bale forks for loader in reply to DJL, 04-10-2007 20:22:41
I have two 3point forks made by a local shop. I modified each by adding an additional 2x4 tube on each side, adding brackets drilled for pins that match the JD 148 loader with quik-tach. Let's me use them on the loader or 3ph, or both at once.
NE IA Dave
04-11-2007 09:44:22
I live in Garnavillo, Ia. population of 700, home town of LL if I can help let me know.
paul
04-11-2007 09:35:17
A bale carrier (like a fork-lift, goes under the bale rather than into it) looks neat, but it is pretty dangerous. If you lift high & tilt the bucket, the bale can roll backwards down the loader arms & make a real mess of the driver.
As well, hard to pull the forks out from under the bale when stacking, or loading on a truck.
--->Paul
rrlund
04-11-2007 07:24:15
I wouldn't go with one that mounts to the bucket. They put the bale too far out front. Worksaver makes a good line of bale handling equipment. I have a Worksaver Balehand on my loader. The website is worksaver.com. They make 360 different tools and attachments,so they are likely to have what you want.
old
04-10-2007 20:31:20
Valuebilt has them listed in there catalog. Don't know much about them I just noticed they had them
Walt Davies
04-11-2007 11:29:23
 Re: bale forks for loader in reply to old, 04-10-2007 20:31:20
$375.99 not bad for what you get and will handle up to 3000lbs. Two forks at bottom of lower rail.
Walt
