Tractor Talk Discussion Forum
1T dually Chev Frnt brake drags, cant fix any Idea
benny2
04-15-2007 07:11:17
I have a 78 1T Chev dually, frnt disc brakes. The Rt frnt brake drags and get hot, it was even locking up and on soft ground the wheel would not even turn. I replaced the wheel cyl caliper module with another that was off a working truck (barrowed) but still drags! So any body got some suggestions. I thought the original was bad but the second is not rite either so where else could be the problem?
Larry D.
04-15-2007 14:55:44
 Re: 1T dually Chev Frnt brake drags, cant fix any in reply to benny2, 04-15-2007 07:11:17
Yes... Those BRAKE LINES will actually stop up, I had one that looked like it had Dirt in it, probably OLD Fluid/Moisture combination, Cleaned it out No Problem!OK after that. Larry
Larry D.
04-15-2007 14:58:50
 Re: 1T dually Chev Frnt brake drags, cant fix any in reply to Larry D., 04-15-2007 14:55:44
TIP; A large Guitar String will be just the thing, stiff and won't fold up.Larry
Bob
04-15-2007 15:02:55
 Re: 1T dually Chev Frnt brake drags, cant fix any in reply to Larry D., 04-15-2007 14:58:50
The rubber inside the brake hose deteriorates, and folds inward, plugging the hose.
WHY would you even attempt to "CLEAN" something this critical?
Replace it, for heaven's sakes, as well as the other rubber brake lines on the truck.
Their "time is up". Don't set yourself up for the same situation!.
Don Wadge
04-15-2007 11:51:51
Just to reinforce whats already been said. I have a friend with a late seventies Chev 1Ton. Same thing happened to him. Replaced caliper and a few other things. Then replaced the hose and that was it.
Wild Bill Caldwell
04-15-2007 08:18:28
I beleive Dave has the right answer here.....Same thing happened with My 79 one ton. Caught Me at a time when I couldn't get the time to shut down and fix it. When it locked up I'd pull the left front wheel and prise the caliper free.BRAKE LINE HAD FRAYED INSIDE....WOULDN'T LET FLUID RETURN. Fairly easy fix,but,TOUGH to thread a new hose in the junction block. Be carefull, Guard against cross threadin'.
Bill Caldwell
old
04-15-2007 08:16:33
Had the same problem on my 1980 heavy half and I replaced the caliper and that didn't fix it. Thne I replaced the rubber brake line going to the caliper and that did fix the problem. May also be where your problem is. The insdie of the rubber brake lines some time gets bad and will let fluid flow in but then not back out and then the caliper hangs up and the brake doesn't release like it should
Steve Crum
04-15-2007 07:29:41
If your changing one hose, plan on changing both. On a truck this old, I would replace ALL the lines on the truck, but especially the front lines all the way from the master cylinder to the wheels. Internally collapsed brake hoses are more common than anyone realizes. These are usually caused by twisting or kinking the hose during front pad replacement. In Pa. if a hose even looks iffy during inspection it must be changed.
J Plunkett
04-15-2007 07:28:05
I had the same problem it was the hoses i'd change both of them other one probly not much better
benny2
04-15-2007 07:35:06
 Re:1Tdually Chev Frnt brake drags, cant fix any in reply to J Plunkett, 04-15-2007 07:28:05
Good point, I think both are original as I have had the truck since 1989. Its a dirt dump bed and gets a lot of real heavy loads. I just hauled 2000 yds of dirt on my farm. Got another 1000 to go.
djw
04-15-2007 07:16:59
Something to check that I have run into a time or two, rubber brake hose leading to the caliper can collapse on the inside and not let brake fluid release. The hose can look normal on the outside. goodluck, Dave
benny2
04-15-2007 07:22:15
 Re: 1T dually Chev Frnt brake drags, cant fix any in reply to djw, 04-15-2007 07:16:59
Yeah I read that in another post, Iam going to get a NEW line next week and give that a try.
Thanks
