Tractor Talk Discussion Forum
ford PTO popping out
BLW
04-16-2007 08:08:52
here I am again-- this has got me stymied-- the pto pops out under load-- can't find anything wrong inside-- so my question is there an adjustment on the lever on the side that puts it in gear-- it's been a long time since I've worked on these so help it has a splined pto shaft not the old paddle type
souNdguy
04-16-2007 12:19:24
 Re: ford PTO popping out in reply to BLW, 04-16-2007 08:08:52
Any in/out play on the pto stub sticking outta the tractor/ if so.. worn bearing.. and it is walking out o fthe coupler.
Other causes could be a worn detent on the shifter.
Rodin gave you good advice.
Soundguy
RodInNS
04-16-2007 08:53:51
What model Ford and what type PTO? Only a guess, but if it's one of the hundred or thousand series, then the snap ring on the rear bearing retainer may be broken or missing. That lets the shaft float enough to do what you describe. You will see end play in the shaft. Probably a 1/4" or better...
Rod
BLW
04-17-2007 06:19:54
 Re: ford PTO popping out in reply to RodInNS, 04-16-2007 08:53:51
rod-- I thought this was a 9N but when I took the pto shaft out it is splined not the old paddle type I'm used to/ so I think it might be a 2N or the whole pto has been changed, but I doubt that-- it does have the mag down in the front like the old 9N-- I have to get back to the barn and find the serial # so I can tell just model it is-- if it is that snap ring can it be put in from the top or does the tractor have to be split thanks bruce
