Tractor Talk Discussion Forum
Diesel conversion for a Farmall H
Mike CA
04-16-2007 22:35:17
Hi gents, I found a diesel engine I want to put in a Farmall H for modified antique pulls. I was wondering if anyone had any advice for the conversion? A pic of it is below. Thanks!
third party image
Maximum power: 108,920 hp at 102 rpm Maximum torque: 5,608,312 lb/ft at 102rpm
MLD
04-18-2007 05:35:49
 Re: Diesel conversion for a Farmall H in reply to Mike CA, 04-16-2007 22:35:17
Good Luck, I would suggest using an M chassis instead of the H, It has a larger hood to cover the engine with.
roger roland
04-17-2007 20:20:51
Ford should have used this instead of there POWER JOKE
Bill(Wis)
04-17-2007 17:02:39
How do they start it? Compressed air?
jimtia
04-17-2007 16:00:45
call jc whitney or summit and see if they have any performance upgrades for it.
buickanddeere
04-17-2007 13:53:39
Two of those will make as much power as the boilers in an Iowa class battle ship. If those ships were ever re-fitted it wouldn't it make sense to scrap the boilers/engines and swap in those 102 rpm brutes. No extensive training as stationary engineers, fast power up & improved fuel efficiency.
4010guy
04-17-2007 11:40:09
That's what they shoulda put it them old JD 4wds. ha ha,,I just hadta say it.
Mydeere
04-17-2007 09:55:37
Rumor has it that Ford is dumping Navistar and is going to put this monster in their F-Series after recent difficulties with the management at Navistar.
I should probably be cafeful about what I say! My comment might end over on that dieselstop website and be construed as gospel. LOL
Kelly C
04-17-2007 07:28:08
Sure it will fit. Done one when I was in the Navy.
The only issue you have is that the starter motor wont fit. You have to hand crank it.
Jim in Ma.
04-17-2007 07:22:59
hey mike - with 102 RPMs I think you would do better in a Slow race. :)
Jim
Buzzman72
04-17-2007 11:30:48
 Here's the secret... in reply to Jim in Ma., 04-17-2007 07:22:59
The secret is in how you gear it. With the right gearing, that 102 rpm won't be a problem...but deciding what tires to use on the H might be.
rrlund
04-17-2007 06:54:04
What weigh class were you planning on pulling in?
dad's88
04-18-2007 07:07:37
 Re: Diesel conversion for a Farmall H in reply to rrlund, 04-17-2007 06:54:04
3750, might have to lose the air cleaner though.
two mile
04-17-2007 06:14:40
I know your kidding, but that would be an ambitious project. Wouldn't you have a little more room in an A JD. Just think, there is probably a whole tractors' worth of iron in one of those pistons or rods. Where's the crank?, and how big of a radiator will you need?
workhorse
04-17-2007 05:27:02
At 102 rpm you not going anywhere very fast
Sam#3
04-17-2007 06:23:24
 Re: Diesel conversion for a Farmall H in reply to workhorse, 04-17-2007 05:27:02
Yeah, but if geared down a bit you're pretty sure to go anywhere.
Dave 2N
04-17-2007 05:13:21
Looks like you could switch it right over to the H; no problem.
bradley martin
04-17-2007 04:23:41
Is that thing turbo'd? There must be fuel tanker plumbed direct to it!!
Rudolph
04-17-2007 03:45:25
I wanna see the can of starting fluid they use on that thing!
TGIN
04-17-2007 02:12:58
You may hav`ta trim the inside of the bellhousing alittle to get that flywheele in there !!
DNWELDMAN
04-17-2007 01:25:57
Yeah, That's wild aint it? It'd prolly fit the cub better than the H. I remember seeing that thing on the discovery channel, that's just pure nuts!!
