Tractor Talk Discussion Forum
One more Resistor Question
newtothisgame
05-07-2007 19:59:28
i put in a resistor from my ignition to my coil and i put it behind my gauge cluster so do those resistors get warm or wont it matter vary little air circulation behind cluster
John T
05-08-2007 04:18:40
 Re: One more Resistor Question in reply to newtothisgame, 05-07-2007 19:59:28
New, if the ballast has a metallic mounting strap/bracket and it has a good mechanical bond to a hunk of iron, such can help dissipate heat as the relatively cooler iron serves as a heat sink. Regardless where you place it, Id use a good secure mount/bond for heat sinking purposes as opposed to letting it hang in air.
John T
gene bender
05-08-2007 04:03:15
why not mount it on the coil where it belongs as lots of the coil mounting brackets have a place for them to mount.
old
05-07-2007 21:20:48
They get real warm/hot at times. If its close to other wires it could cause problem. I find the best place to mount them is on some steel some place that way the steal helps disapate the heat sort of works like a heat sink
Gerald J.
05-07-2007 20:12:28
Might actually be good at boiling the condensation out of the gauges.
Gerald J.
uncle
05-07-2007 20:04:39
They can get warm. Most auto ballast resisters are mounted in the firewall. My dad put his under the hood by the headlights on his 9N.
Brian
