Tractor Talk Discussion Forum
Howse 6' bush hog (washer holding bell to shaft)
David Lee Hawki
05-13-2007 14:13:43
There is some kind of washer with multiple teeth that slips around the shaft of my Howse 6' bush hog. The bell housing with the blades attached go onto that shaft and the nut/washer tightens it all down.
The shaft has teeth cut into it on the end that fade smooth about an inch and a half up the shaft. I am missing the washer that fits on the shaft. The blades and the bell shaped disk slip around the shaft easily.
The person I purchased the tractor from had tack welded the bell shaped disk to the mower shaft. That is a bad idea and I would like to fix it correctly.
Where can I get one of these washers?
Is there an alternative solution?
Thanks,
David Hawkins
PGN
05-14-2007 04:34:48
 Re: Howse 6' bush hog (washer holding bell to shaf in reply to David Lee Hawkins, 05-13-2007 14:13:43
Try this.
www.howseimplement.com
oliver power
05-14-2007 04:11:49
Hi Dave , not to long back , I had ordered parts to rebuild my entire gear box for an old 6 foot "Hi-Co" rotory mower. Hi-Co is an older "Howse". They are located in Mississipi. I wish I had the phone number handy for you , but I don"t. Have the operator look it up. I just recently came accross the reciept again. I"ll check to see if I can find it tonight.
Rod in Smiths Falls, ON,
05-13-2007 17:15:13
eBay 260116795587
This guy is a very helpful vendor and knows rotary mowers. When I faced a similar problem with a Walco Whistler he supplied me with diagrams of his product. Later he sold me one of the gearboxes listed above. It fitted right on and works very well. He regularly lists a wide variety of rotary mower products.
