Tractor Talk Discussion Forum
what to do if your hay gets wet during drying/bali
ssg shelton
05-13-2007 18:31:09
Thanks for the answers on my other questions. I have another one. Say during the time after I cut my hay until the time I get to bale it (probably 4 to 5 day) what happens if it gets rained on while laying out in the field? I have a sickle mower and 273 baler but no conditioner or tedder so it will take a while longer for me. Thanks
Joel
Kelly Campbell
05-14-2007 10:52:34
 Re: what to do if your hay gets wet during drying/ in reply to ssg shelton, 05-13-2007 18:31:09
you can use either a wheel rake or a bar rake and take care of this as well, a wheel rake will tet the hay in one of its set-ups and with a bar rake you can set it to take off the top half of the windrow and then turn over the other half...works...
Allan In NE
05-14-2007 04:10:55
Don't know about where you live, but out here, I would drop to my knees and give thanks to mother nature for sending the moisture. :>)
Allan
old
05-13-2007 19:31:09
I've had it happen off and on in the past 25 or so years I have baled hay. If in windrows then that can be a problem but if still just laying on the ground, let it dry a day or 2 then rake it up as fluffy as you can and let it sit a few ors or till dry and bale it. Most of the time you will lose a little quaitly but not much. If in windrows you need to turn the windrow a few times and then you can save it but it will not be as good as it would have been if just laying
dds-inc
05-13-2007 19:22:08
If you run that tedder right after the rain it should get it up off the ground a little.
Although a tedder helps, sacrificing hay quality during rain is just.... a part of life!
Jimmy King
05-13-2007 18:58:33
First of all I don"t know where you are. It Southwest MO where I am I would let it lay until it is fairly dry then rake it as loose as I could. If it is raked when rained on raise the discharge end of your rake up about 10 inches you may have to play with this a little and turn the windrows by raising the outer end it will scatter the hay some and help with the drying.
kyhayman
05-13-2007 18:52:02
If it gets wet in the windrow, its a mess. Even with a tedder not much salvage to it in a humid climate. On the ground, with a tedder, its not a huge problem, just hurts the quality and color. Without, all you can do is let it dry on top, turn it with a rake, and turn it again, and again.
There are a world of tedders sold when hay gets wet unexpectedly. A two basket runs about 1500.
