Tractor Talk Discussion Forum
IH 574
dave 66
05-14-2007 10:13:26
I have a 574 and I cannot get the side shifter to go into reverse. It seems to be stuck in the middle.It won"t shift to the low gear side. Any suggestions would be appreciated. Thanks.
DAVE 66
05-15-2007 12:09:39
 Re: IH 574 in reply to dave 66, 05-14-2007 10:13:26
I took the gear shift cover off and worked with the linkage and fixed it. Thanks!!!!!
Jim in Ma.
05-14-2007 15:47:17
I had that problem too = Remove the sheet metal behind where your Left foot rests.
You will see the leavers when you wiggle the shifter. One of them has to be pushed back .
edwinb
05-14-2007 11:51:59
get under the tractor , engine stopped etc, and have a helper wiggle the gearleaver uou will see what has got out of alaignment a strong screwdriver might be helpfull not brute force. there is now some age related wear on the gear linkage easily repairable i believe , if it has only happened once yet it may not happen again for a while if you use positive movements , into neutral accross then into gear
georgeky
05-14-2007 10:23:41
Check the shifting linkages. You will have to remove some of the tin to do so.
