Tractor Talk Discussion Forum
O/T Chev citation
old
07-10-2007 17:36:47
Well my wifes car is an old chev citation. Well she put a hole in the tranny pan so I replaced it today, but it also has one bolt missing in it. I know I used a 1/2 inch wrench to remove the bolts but when I checked the bolts are not 5/16s so do any of you by chance know what size it is????? ??? By the way its an automatic
Thanks
kurt:ky
07-11-2007 18:16:30
 Re: O/T Chev citation in reply to old, 07-10-2007 17:36:47
Told you that last night. lol. have a nice day.
Allan In NE
07-11-2007 04:23:17
Old,
That's probably a 125-C tranny and every blessed bolt in it is metric. Takes a 13-mm wrench/socket on the pan bolts.
Allan
old
07-11-2007 09:35:27
 Re: O/T Chev citation in reply to Allan In NE, 07-11-2007 04:23:17
1/2 inch socket worked just fine. Ya there metric and yes its the 125 tranny. Found out today it takes a 8mm bolt with 125 tread pitch so I have a couple now sitting on the will call shelf of the parts store just waitig for me to drive in and pick them up
Thanks
doogdoog
07-10-2007 22:06:50
Aloha, Just remove one of the bolts and take it to your auto parts store and match it up if you don't have a screw gauge.
Mahalo,
doogdoog
onefarmer
07-10-2007 20:12:12
I don't know the correct size but it will be a metric for sure. The Citations came out during the last year or two of HS for me.
dds-inc
07-10-2007 18:31:00
When I first looked at your topic, I had thought you recieved a traffic citation in a chevy.
never heard of such a vehicle.
Leroy
07-10-2007 19:47:27
 Re: O/T Chev citation in reply to dds-inc, 07-10-2007 18:31:00
Early 80's front wheel drive sedan
kurt:ky
07-10-2007 18:26:54
Try an 8mm with a 1.25 pitch.
RayP(MI)
07-10-2007 18:18:33
Just a guess here - Metric? 1/2 inch is approximately 12mm.
onefarmer
07-10-2007 20:09:55
 Re: O/T Chev citation in reply to RayP(MI), 07-10-2007 18:18:33
accually 1/2in is closer to 13mm. 13mm is just a bit bigger but 12mm is more smaller.
Ryan - WI
07-11-2007 05:21:48
 Re: O/T Chev citation in reply to onefarmer, 07-10-2007 20:09:55
But if he took them out with a 1/2" they must have a head size of 12mm. If they were 13mm the 1/2" socket would have been too small.
onefarmer
07-11-2007 11:07:54
 Re: O/T Chev citation in reply to Ryan - WI, 07-11-2007 05:21:48
A 1/2 wrench fits snug on a 13mm head but it will fit in most cases. All the 12mm I tried a 1/2 wrench on was always too loose to get a grip, not that it can't sometimes.
Using a 13mm wrench on a 1/2 head will grip but is just loose enough to round the corners off so care is needed.
While I'm no professional mechanic I've turned many wrenches for 44 years.
