Tractor Talk Discussion Forum
Iseki diesel fuel problems
geok
07-25-2007 03:54:03
A fellow down the road from me has a Iseki 3cyl. diesel tractor that dies after running for about 3 minutes. His problem is in the injection pump. Someone that owned it before him plug the injection pump return line to the tank. This tractor has ran this way for a few years now up until this new problem. After you bleed the system and then run engine for about 3 minutes, it dies. Then a blast of diesel fuel comes out of the air vent near the top of pump between it and engine block. When I saw the return line had been plug, I reconnected it to the return line to the tank. But it still starts runs for about 3 to 5 minutes then blow fuel out of breather tube and dies. Any ideas? Thanks for your help.
MSM
07-25-2007 05:36:38
 Re: Iseki diesel fuel problems in reply to geok, 07-25-2007 03:54:03
Check the fitting the return line is attached to. It should have a check ball to keep fuel from backflowing. The check valve may be stuck or blocked.
dej(JED)
07-25-2007 05:03:08
That is a bypass line to prevent pressure building up.
