Tractor Talk Discussion Forum
WAL-MART OIL
alan bane
08-16-2007 11:54:01
I wonder if wal mart oil is as good as the name brands.You know it has to be made by a major co.
djm75
08-18-2007 04:40:07
 Re: WAL-MART OIL in reply to alan bane, 08-16-2007 11:54:01
walmart is putting everyone out of buisness due to their size and pull manufacturing. The also own over 80% of the factorys in china. Buying from walmart is like giving american jobs away. you can believe it or not but its the truth.
farmerweber in PA
08-17-2007 22:34:17
The back of the jug used to say packaged by Pennzoil/Quaker State.Couple of years ago it switched to distributed by Wal -Mart.Don't know if it still is or if it went to the lowest bidder.I run the 15-40 and havn't had any problems though.
Dachshund
08-17-2007 14:50:33
Been using nothing BUT Wally Super-Tech for years. I got 350,000 miles on an F-150 with zero problems. I use it and will continue to use it in everything I own.
Dave Sherburne NY
08-17-2007 09:59:11
I tried it once in my truck and the engine started
using oil. I changed back and it stopped using oil.
JT
08-17-2007 09:25:00
I use it as assembly oil, works good for that. I do not think I would look for the cheapest oil to use in a $15-50,000 vehicle. As I tell my customers, it you can not afford to buy the appropraite oil and filters for the things you or own, you should not be buying it ot owning it.
dej(jed)
08-17-2007 08:08:16
You get what you pay for. It is a minimum spec oil. We test oils every year at the lab and it is no different than any of the other cheap ones.
It just passes..... .
barnrat
08-17-2007 06:12:47
First off Wal mart or TSC doesn't get a dime of my money. I use enough oil that I buy in bulk directly from a local blender/packager that is right up the street from the refinery that made the oil. They are a lot cheaper than wal mart and they stand behind their product if there was ever a problem.
Andy Motteberg
08-17-2007 06:00:30
If you are referring to SUPER-TECH engine oil, don't get it, its no good. Your engine will bang and knock and be noisy. My Dad once put that in the engine of his truck and it sounded so bad, he drained out that oil and put in good oil and it ran good.
bluepaint
08-16-2007 22:44:40
There's a thread on another forum that has been going for months on this subject and it's getting boring but the general thought is that they are fine , Many others like my-self use them in tractors ,combines and construction equipment from 1940's vintage CAT's to $250'000 combines and had no problems , As soon as it's out of warranty . 11 tractors ,3 combines and 4 heavy trucks and we've had no problems .
mike in md
08-16-2007 21:38:51
It may be blended by a major oil company,but it is blended to just barely meet the specs, so they can keep the price low.It is like the rest of the stuff that WalMart sells,it lasts for alittle while but eventially craps out or fails.If you have an old junker that slobbers,leaks and burns oil,run the cheap stuff, but think twice before you put it in anything decent.
Chris in MD
08-16-2007 20:58:00
NOT wal-mart oil. If you compared that to, say, pennzoil, you would notice that the walmart oil is more viscous and almost transparent.
If you ask me, the stuff looks like vegetable oil, and smells sort of funny.
would NOT put it in anything newer.
RodInNS
08-16-2007 18:38:35
People can believe what they want. I look at the spce on tha bucket. The TDH claims to meet the spec for Ford/NewHolland 134D, so I use it. It works fine at half the price of OEM branded oil.
When you blow enough hoses and get a few leaks that just don't get fixed, you'll find that Walmart oil works just fine, at least until you can fix the leaks...
I don't find any of their oilo to be inferiour...
The biggest thing I hate with it is dragging the 2 or 3 buckets that they might have from the back of the bloody store when most other places would at least have it handier the door...
Rod
Tradititonal Farmer
08-17-2007 01:18:35
 Re: WAL-MART OIL in reply to RodInNS, 08-16-2007 18:38:35
People with dead cats and dogs looked at the 'specs' on the can of Chinese made pet foods from Walmart
and ended up with dead pets. Moral:Don't believe everything you read in the paper or on a can. One bad batch of oil will ruin an engine.
RodInNS
08-17-2007 07:42:49
 Re: WAL-MART OIL in reply to Tradititonal Farmer, 08-17-2007 01:18:35
You can believe whatever you want....
I believe that the Walmart branded oil is just as good as anything else out there, and probably better than some out there.
IN fact I know that it's better than some out there. I did a brake and FWD clutch job on one tractor already from using Ultramar oil that didn't meet the specs, but was advertised to by the dealer.... It was walmart oil that went in afterwards for no reason other than to flush the crap out of the tractor... and lo and behold it started working better. The brake noise went away. The gear whine went away... and it cost half as much.
I'm not going to say that the additives will stand up to the long service intervals that were recomended by the manufacturer using their oil, but when you're in the position of dumping oil every hundred hours to flush crap out of a system, or you're fighting a battle with leaks on old equipment, I see absolutely no reason to not use walmart oil, or Canadian Tire oil, or whatever other cheap oil that meets the spec for the machine.
SO far as the engine oils are concerned, LOOK A THE API RATING. If it's got it, it's good. That's all I worry about.
Walmart may sell a lot of junk, but they also sell a lot of quality products at very competitive prices. I for one don't see a thing wrong with the oil.
There's just too many people in this world that are so spooked by "oil" that they have to go and buy the expensive oil from a dealer, and the dealers are glad to take your money. When somebody shows me a difference where a lubricant that met "spec" underperformed, then I might listen, but I've yet to see the evidence. That goes for the snake oil salesmen that try to hawk the high end products that are supposed to save you piles of money on repairs.... In some cases it works, and in most cases those operations have very good preventative maintenance programs anyway.... so if they did that with normal lubricants they'd probably have about the same luck. Sorry, but that's ho I see it.
Rod
dhermesc
08-17-2007 06:35:22
Actually that pet food was made in Kansas (not China) by an American company called Menu Pet Food and was shipped to retailers nation wide - not just Wal-Mart.
David Snipes
08-17-2007 08:26:20
 Re: WAL-MART OIL in reply to dhermesc, 08-17-2007 06:35:22
But the wheat gluten in the pet food came from China.
dhermesc
08-17-2007 08:38:28
 Re: WAL-MART OIL in reply to David Snipes, 08-17-2007 08:26:20
"But the wheat gluten in the pet food came from China."
You point is what? The American manufacturer used an inferior product and it was sold everywhere - hardly just a "Wal-Mart" product.
US manufacturers use products from nations all over the world. General Motors uses engines produced in China - Ford uses French built transmissions, going to buy a Toyota instead?
Just so you know Tech 2000 motor oil is refined in the US but probably from oil pumped from Venezuela.
hayray
08-16-2007 18:18:08
It is about the only stuff I buy. It meets all the manufacture specs and is about half the price that my dealer was selling me the 30 gallon drum of oil for. I think it is packaged by Shell Rotella.
marlowe
08-16-2007 16:04:57
just like buying gas do you think shell sells there own gas or mobil no it all comes out of the same tank. brother drives a tanker and will drope at all brands of stations with the same gas
Steven f/AZ
08-16-2007 15:25:11
bobistheoilguy.com
randy hall
08-16-2007 15:02:47
walmart oil is just like the tires that they sell. they are using brand names with a lesser quality product. go ahead and buy walmart stuff. when they run every ma and pa business out of the country they can charge whatever they want. they made eleven billion in profit last year. maybe they will buy your kids a plane ticket to china to get a job.
Kansas Cockshutt
08-16-2007 18:54:45
 Agreed in reply to randy hall, 08-16-2007 15:02:47
Why not support your local parts jobber instead of supporting Communist wal mart? Do you think Wal mart will come in some crazy hour and make you a hydraulic hose or pull a bearing for you when you need it NOW?
Spend the extra nickel or dime and help out a fellow American. Your jobber sells oil. Remember the golden rule and if you don"t then do not be suprised when you are in a pickle with no place to buy your parts or stuck with an employee that is completely ignorant of anything mechanical.
I just thank God I live in a part of the country where people still can have trust in each other, the choice to buy quality, and live free. The big box epedemic is eroding America and poisioning children -sic.
dhermesc
08-17-2007 06:38:51
 Re: Agreed in reply to Kansas Cockshutt, 08-16-2007 18:54:45
Just wondering - where are these mom and pop stores that only sell American products? The ones I've been in are selling the same Chinese made crap as Wal-Mart only at higher prices while paying their employees less.
RodInNS
08-17-2007 07:50:05
 Re: Agreed in reply to dhermesc, 08-17-2007 06:38:51
I agree with that statement 100%. I find I'm better off going to some fo the surplus type stores for better quality stuff actually... I've got a hydraulic valve here right now that needs to be replaced that was bought from one of the local industrial suppliers. It was and is JUNK, they aren't going to give me anything on it, but I can buy another piece of junk from them... I go to Princess Auto, it's satisfaction guarnteed, or money refunded, and I have no doubt that they will make it right. I find that they carry as much quality stuff as junk too. You just pay a bit more for the quality.... but the local industrial supply is selling the JUNK for the same price that Princess sells the goos stuff, so figure where my money is going. When that's the kind of service I get locally, I find it hard to go back. If they had service, I might pay more.
Rod
bluepaint
08-16-2007 23:11:26
Who's the communist ?..... .I live in quite a large town and afer 12 on saturday you can't get nothing even week days is only 9-5 even big NH or IH dealers do better than that , Are we going back to union crap ?
Gol durn Walmart :-)
08-16-2007 18:34:23
 Re: WAL-MART OIL in reply to randy hall, 08-16-2007 15:02:47
Randy, how does Walmart drive a mom & pop store out of business ? Cant say I have ever seen an armed Walmart guard outside a mom & pop store turning customers away and demanding that they shop at walmart. You think maybe it's people like you and me that drive right past the mom and pop store on our way to Walmart where we can get more variety at a lower price ?? I think it was Pogo Possum that said " I have seen the enemy and he is us" ;-)
John M
08-16-2007 14:55:36
I cant find it now for the life of me, but some of it is bottled by Valvoline, not sure which grade or spec they did, but I know that it was at one time. Ive ran their deisel rated oil in my Stroke a few times and seems to run just fine with it.Rotella is often times the same price so most of the time I just grab it.
Leland
08-16-2007 14:55:05
Ask JT about wally world brand oil he has posted that he has had several pieces of equipment that died from oil failure in his shop from there name brand oil .
jocco
08-16-2007 14:18:51
saw a gas tanker pull in filled the rerular tank then the super/premium one. I asked what is the difference here same truck only one tank?? Guy smiled and sayed 10 cents a gallon more.
Jay (ND)
08-16-2007 19:23:19
 Re: WAL-MART OIL in reply to jocco, 08-16-2007 14:18:51
Someone fooled you. Most of those tankers have at least 4 compartments.
dhermesc
08-17-2007 06:45:10
 Re: WAL-MART OIL in reply to Jay (ND), 08-16-2007 19:23:19
I doubt it.
I had a 1967 Ford with a 289 that had the compression upped to around 10.5 to 1. Took me about a year to finally figure out why the car would run perfect for a while then would ran like crap with all kinds of knocks and pings then suddenly start running fine again. Three stations in town where selling regular as high octain and two were selling what they advertised.
georgeky
08-16-2007 12:50:32
Just like off brand canned goods. Lots of these things are made in the same plants as name brand stuff and another label put on it. My dad hauled Ketchup,beans,corn,peas and so on and the cannary had about 10 different labels they put on their name brand goods. He also hauled Bob White syrup and they done the same thing. I have used Wal- Mart oil and no problems with. Even used Wal-Mart hydraulic oil.
jason, NW Ontario
08-17-2007 04:15:41
 Re: WAL-MART OIL in reply to georgeky, 08-16-2007 12:50:32
Sorry to disappoint more fellas out there, but it's the same story with your automotive batteries. A local guy worked 9 years ago at a plant near Toronto that slapped different company stickers on the same batteries before shipping. He quit shortly after starting, but said he easily saw a dozen company labels.
jason
buickanddeere
08-16-2007 19:46:02
 Bob White Syrup Re: WAL-MART OIL in reply to georgeky, 08-16-2007 12:50:32
Never heard of Bob White Syrup till now. According to the web site their Maple Syrup is a blend instead of 100% pure. What is the world coming to when somebody dilutes real Maple Syrup. I can't imagine pancakes with anything else.
georgeky
08-16-2007 23:15:37
 Re: Bob White Syrup Re: WAL-MART OIL in reply to buickanddeere, 08-16-2007 19:46:02
40 years ago when dad hauled the stuff is was pure syrup. I haven't seen any in years.
Tradititonal Farmer
08-16-2007 12:36:10
Since even the highest priced oil is a small fraction of an engine rebuild why take a chance?
Gary from Muleshoe
08-16-2007 12:28:30
My father-in-law used it all the time in his 2004 Chevy PU. He said it was as good as Quaker State or any other name brand. He has since past away, but I always trusted his word. He was an honest man and would not tell a lie.
buickanddeere
08-16-2007 12:10:12
I wonder when there are counterfeit oil filters, air filters and nuts/bolts/washers. Is there any chance somebody might be re-labeling cheapo oil as the top quality product?
Sid
08-16-2007 11:55:58
It is as good as the rating on the label.
Leaky Boot
08-16-2007 11:59:10
 Re: WAL-MART OIL in reply to Sid, 08-16-2007 11:55:58
Do you have more information?
Sid
08-16-2007 12:25:20
 Re: WAL-MART OIL in reply to Leaky Boot, 08-16-2007 11:59:10
Do you want information or an explanation? In the way of an exclamation. "It is as good as the rating on the label". Wal-Mart oil is required to meet certian minimum specs in regards to its intended use just as any other label. If you want information do a search on oils and many websites are out there that explain the differant rating and specs for oil and their specifactions.
Leaky Boot
08-17-2007 04:39:18
 Re: WAL-MART OIL in reply to Sid, 08-16-2007 12:25:20
You believe them? Truth won't be know until it's too late and then you can't say for sure it was the oil. Printing on a container is easy to do. All contents are tested?? Have you even see what base is used on most Hyd oils? Nap. or Par. ?? That's the difference in hard use.
Leaky Boot
08-17-2007 04:35:42
You beleive them?
