Tractor Talk Discussion Forum
More snapper problems
Lanse
08-18-2007 12:20:18
One of my friends was driving it around and all of a sudden there was a cloud of white-blue smoke 50' long and a good 20 high!! Looked at it, and saw there was oil in the carborator. rinsed it with gas, and pulled/cleaned the head, and now it dont smoke, much, but only runs on full throttle/choke. Any pointers appriciated. Thanks alot.
Janicholson
08-19-2007 21:04:20
 Re: More snapper problems in reply to Lanse, 08-18-2007 12:20:18
Dear lanse,
If it still is running poorly, look to what you have been told. The tin breather behind the carb is designed to have controlled vacuum applied and it has a reed valve in it Fix this and I think it willrun well. JimN
Gene Davis (Ga.)
08-18-2007 20:26:53
Overspeeding can cause this as well as a breather valve for the crankcase with a speck of trash or carbon under the reed valve.
bryonwayne
08-18-2007 17:20:22
the prob is the govenors came out.. thus opening up full throttle.. , small motors are a hobby. for 40 years
Blue3992 (N Illinois)
08-18-2007 16:59:06
I don't think you really needed to pull the head.
Oil made it's may into the combustion chamber. That can happen on a garden tractor if the oil is over-filled or you're driving on a hill (amongst other possibble causes).
No idea why it needs full throttle/choke.
Andy Motteberg
08-18-2007 16:10:38
You might have a broken or worn piston ring.
