Tractor Talk Discussion Forum
Tractor weight
DW in Indy
08-31-2007 15:34:23
OK guys, my transmission is counting on you. I"m trying to buy a Farmall C tractor and need to haul it about 350 miles. A trailer will weigh around 2000 lbs. but I need to know the weight of the tractor. Just want to make sure I don"t have to buy a transmission when I"m done pulling it.
big N
08-31-2007 17:56:08
 Re: Tractor weight in reply to DW in Indy, 08-31-2007 15:34:23
yah a half ton truk should do it just as long as you have a strong enough trailer
RobMD
08-31-2007 15:53:18
A half ton pickup can handle a farmall C. Just make sure you have two axles and working brakes.
As for your tranny, DON'T FLOOR IT!
Lanse
09-01-2007 07:50:10
 Re: Tractor weight in reply to RobMD, 08-31-2007 15:53:18
Huh? Don't What? Awww, nuts. =)
2900lbs, a little more then a 8N
doug in illinois
08-31-2007 17:23:23
I agree with the comments posted so far. Used to pull a bumper hitch 16 ft livestock trailer with anywhere between 5 and 12 head of cattle behind a 66 Chevy half ton short bed stepside, no problem. That was before trailer brakes were common. Anyhow, IF YOU have any experience pulling trailers, should be no problem. I have pulled a Ford 5000 diesel behind a 91 Dodge half ton with no problem, the 5000 is a more than 6000 lb tractor. Just need to know what you are doing. That means if you are on some of the cement poured roads where every joint in the pavement bounces harder, you need to slow down or get on back roads where you don't have to deal with that issue.
georgeky
08-31-2007 19:55:38
 Re: Tractor weight in reply to doug in illinois, 08-31-2007 17:23:23
That 5000 must have had fluid or weights then. I have a 7610 that only weighs 6000 with no fluid or weights.
doug in illinois
09-01-2007 09:11:53
 Re: Tractor weight in reply to georgeky, 08-31-2007 19:55:38
Yes had fluid. Right out of the operators manual weight less options is 5330 lbs.
georgeky
09-01-2007 09:41:05
 Re: Tractor weight in reply to doug in illinois, 09-01-2007 09:11:53
I was just wondering as the manual for my 7610 said it only weighed 56 or 5800. Don't remember exactly, but do remember thinking a 86 HP tractor should be a lot heavier than that. It has been a very good tractor though. Does have fluid and 500 pounds on the front.
Ole Sow 53
08-31-2007 15:42:11
Close to 3000# without fluid in tires.
Gary from Muleshoe
08-31-2007 15:40:15
A Farmall C will weigh some where in the ball park of 2900 lbs. Depending wheel weights and if there is fluid in the tires. Yo didn't say what you are pulling it with but it should cause you any problems in 1/2 ton pickup or equivalent.
