Tractor Talk Discussion Forum
Torque Pattern
James in Al
09-19-2007 05:08:23
I am in the process of rebuilding a 47 H Farmall. Can anyone tell me the correct torque pattern for the head bolts. The IH shop manual calls for 70 ft. lbs. but does not mention the proper sequence when tightening.
triplerange
09-19-2007 05:33:22
 Re: Torque Pattern in reply to James in Al, 09-19-2007 05:08:23
If you don't do the increasing torque amounts like Allan's says, you end up stripping the threads out of the block like I did on two holes. Then you get to put heli-coil repairs in the holes...not fun but works.
Allan In NE
09-19-2007 05:16:36
On cast iron heads, start in the center and go in an ever increasing circular pattern toward the outside.
Also, do it in three repetitions with increasing torque values.
Allan
James in Al
09-19-2007 05:47:15
 Re: Torque Pattern in reply to Allan In NE, 09-19-2007 05:16:36
Thanks
