Tractor Talk Discussion Forum
Getting a crank shaft ground
INCase
09-28-2007 08:07:43
Roughly, what is the going rate for a 4 cylinder crank shaft grinding/refinishing? I know it will vary from shop to shop but trying to get an idea on costs to make some desisions. Thanks.
INCase
09-30-2007 05:35:05
 Re: Getting a crank shaft ground in reply to INCase, 09-28-2007 08:07:43
Thanks for the replies. I"ve measured it a couple times now (2 different ways) it looks like #1 is at the limits of the out-of-round and taper. We"ve got a shop that can do it but he final charge is always 20% more than his estimates so the info provided helps. Thanks again.
Jim Johnson
09-29-2007 04:43:32
Well if it cost that much you might as well go to a salvage yard and get a good crank. I've bought them for a lot less.
Jim
rrlund
09-29-2007 18:22:57
 Re: Getting a crank shaft ground in reply to Jim Johnson, 09-29-2007 04:43:32
That one that cost me 350,was quite bad,had to be built up and reground,then ground the rest to 10 under come to think of it.
Spook
09-28-2007 20:15:20
Wow, last one i had ground was 10 years ago, done at an automotive speed shop, charged me $75.
SDE
09-28-2007 18:07:43
Farmall 400 crank, ground and I had them order the bearings so that I would not have to worry about them either. $225 SDE
rrlund
09-28-2007 14:10:27
Last 6 cylinder I had done cost me around $350 if that helps.
Maark
09-28-2007 10:24:48
Why not call the experts at a machine shop? Tell them what you have and what you want done.
