Tractor Talk Discussion Forum
How many gallons of antifreeze in MH 44-6?
Dalton S.
10-17-2007 05:24:53
How many gallons of antifreeze go into a Massey Harris 44-6? It has a continental engine. Any advice is greatly appreciated.
Walt Davies
10-17-2007 08:59:29
 Re: How many gallons of antifreeze in MH 44-6? in reply to Dalton S., 10-17-2007 05:24:53
Your MH 44-6 holds 4 gallons of coolant. Put in 2 gallons of antifreeze and fill it up with water. Don't waste your money on distilled water it won't make a bit of difference. Water is water (H2O) unless you have some pretty awful stuff at your place just use tap water. Unless your water is full of iron, alkali or other minerals that coat your pipes and outlets I wouldn't get to excited about using it.
Walt
msb
10-17-2007 06:04:05
Why not just buy the premixed and pour it in.
in-too-deep
10-17-2007 12:50:32
 Re: How many gallons of antifreeze in MH 44-6? in reply to msb, 10-17-2007 06:04:05
'Cause pre-mix is a racket and a rip-off. You'd think 50% anti-freeze would cost half as much as full-strength anti-freeze. Not so. Don't pay for water.
Rich Va
10-17-2007 05:47:15
You need to find out the capacity of the cooling system. Then mix a ratio of 50/50,40/60,30/70 etc.etc. with distilled water. 100% anti-freeze will not have as much protection when used alone. Usually the anti-freeze jug will have a chart to show what to mix for low temperatures.
