Tractor Talk Discussion Forum
Spray on truck bed liner - DIY?
Kent in KC
10-31-2007 09:00:29
(The truck I use to haul my tractor, etc. etc.)
Orscheln sells spray on bed liner stuff, I guess similar to Rhino Liner. Has anyone here used it and do you have any recommendations one way or the other?
Thanks.
dave guest
10-31-2007 18:20:48
 Re: Spray on truck bed liner - DIY? in reply to Kent in KC, 10-31-2007 09:00:29
Rusty you are right on! When I bought a truck the salesman said what kinda liner you want? I said I dont need any until bed is all screwed up and then I put one on and sell truck back to you.
Ben Rauls
10-31-2007 16:22:32
I had Line X, would have it in my next truck in a hear beat, took alot of abuse, never chipped or peeled
Walt Davies
10-31-2007 15:51:50
I use the replaceable rubber liners they can removed and the bed cleaned and they can be washed. and I have aluminum at both end and on the side tops. Looks good and protects. I could car less what the next guy gets that's his problem. I use my trucks till worn out anyway.
Walt
Kent in KC
10-31-2007 11:31:45
Thanks gents. Yeah, I know it won't protect against dings. Sounds like, like most things, if you follow the directions, including a good job of surface prep, it should be okay.
RustyFarmall
10-31-2007 09:33:48
That bed-liner stuff is way over-rated. It might prevent a few scratches, but it sure won't stop the dings. I think a better option is too just use your truck the way it came from the factory and when it's time to trade it in, re-paint the bed.
RobMD
10-31-2007 09:56:41
 Re: Spray on truck bed liner - DIY? in reply to RustyFarmall, 10-31-2007 09:33:48
it prevents schitt from sliding around in the bed. It's not quite as overrated as you might think. I've had rhino linings in my trucks, they've all lasted for over 10 years now.
BENJAMIN KIMM
10-31-2007 09:18:25
the previous owner of my truck put a roll on type bed liner on and it is chipping and flaking off. Some of them turn out nice, but mine was a crappy job. Surface prep is deffinatly the key, as is putting on enough coats. One of my farms other trucks has Line-x and we love it. my position- do it right or have it pro done
rustyj
10-31-2007 18:19:00
 Re: Spray on truck bed liner - DIY? in reply to BENJAMIN KIMM, 10-31-2007 09:18:25
My son works at Ziebart, doing the bed liner trick! He says there is a lot of preparation work before applying the liner coats. Sanding the finish, masking and other things. Then he has to put on some clothing, masks, gloves, breathing air, all that heavy stuff, to protect his lungs! He says that several whiffs of that stuff in the lungs will make ya eligible for a coffin, in short order!
