Tractor Talk Discussion Forum
1951 John Deere R Diesel
prvtpilot
11-03-2007 09:49:56
How do you check the engine oil level? Can someone help me with how to check the oil and how much it holds? Thanks
David from Kansas
11-03-2007 14:30:34
 Re: 1951 John Deere R Diesel in reply to prvtpilot, 11-03-2007 09:49:56
On the right side of the tractor just below, and slightly behind the fuel sediment bowl is a petcock which has a 3/4" hex head on it. Loosen it three or four turns and oil should run or drip out the hole on the bottom. The crankcase has a 13 quart capacity.
prvtpilot
11-04-2007 09:43:24
 Re: 1951 John Deere R Diesel in reply to David from Kansas, 11-03-2007 14:30:34
Thanks for the information David, where is the kill switch? My tractor won't start, I'm thinking the kill switch is stuck or something. We even pulled it off and it never hit once! Any ideas? Thanks
