Tractor Talk Discussion Forum
electrical issue with Toro/Wheelhorse 264g/model 72042
tom rasmussen
12-19-2007 18:22:18
need help with my wheel horse toro
14 hr Kohler 264G
model #72042
serial number# 5901-003
The tractor starts fine when cold
after use the tractor will turn over fine, but will not start.-- Acts like the engine is not getting spark. I took the spark plug out last summer when warm & no spark from spark plug. 2 hrs later the same spark plug started the engine.
this warm starting issue has been going on for several mos.
there are several cutoff switches such as : 40lbs + on the seat, mower is off, neutral clutch & brake are engaged.
any ideas??
thx
I changed the gas filter
Dan-IA
12-20-2007 09:00:55
 Re: electrical issue with Toro/Wheelhorse 264g/model 72042 in reply to tom rasmussen, 12-19-2007 18:22:18
I vote to replace the condensor.
old art
12-19-2007 19:18:16
does the oil pressur switch kill the engine on low oil presure try with it unhooked
patsublett
12-19-2007 19:06:47
Disconnect the ground wire where it goes under the cauling to the mag., when it won't start. that eleminates all safety switches. if it starts, you will have to choke it to kill it.
was jd-tractor
12-19-2007 18:32:30
problem is most likely the coil ,breaking down when hot,it it has points ignition it could be the condensor
LenND
12-19-2007 18:46:22
 Re: electrical issue with Toro/Wheelhorse 264g/model 72042 in reply to was jd-tractor, 12-19-2007 18:32:30
Sounds like points. I would buy an electronic ignition set if available. And throw away the points cause they have a lot better spark.
