Tractor Talk Discussion Forum
98 monte carlo problems
newtothisgame
01-26-2008 14:46:46
98 chev monte carlo 3.1L when slowing down the engine seems like its misssing and spudders and spits when at high speed or RPM no problem anyone else ever have this problem or might know whats wrong already been to the repair shop twice thanks for any help
bradk
01-27-2008 08:15:55
 Re: 98 monte carlo problems in reply to newtothisgame, 01-26-2008 14:46:46
More info.
Is the service eng light on/flashing?How many miles? Tune-up lately?Start doing it suddenly or over time?Explain missing,spuddering and spitting.Backfire?Exhaust loud?
olddog
01-27-2008 04:35:49
Converter lockup not unlocking? Try tapping the brakes only enough to put the brakelite on.
Allan In NE
01-27-2008 03:55:58
Don't 'spose the muffler has a baffle loose?
Allan
Goose
01-26-2008 19:45:15
If it happens when you're slowing down and not while under load or at RPM, I wouldn't think it would be a fuel delivery problem.
I'd suspect an emissions problem. Either have someone run an OBD II scan to see if it has any codes stored, or you can go to Walmart and buy your own OBD II scanner for about the same price as what a shop will charge to scan it.
El Toro
01-26-2008 15:05:02
It may need a a new fuel filter. You should measure the fuel pressure to what that is at high speed when it starts the sputtering. If the fuel pump is in the gas tank it may have dirt or rust blocking the pump inlet. Had that problem on a Chevy Citation. I dropped the tank and it was full of rust. I cleaned the tank and installed a new pump. My neighbor said I wouldn't change that pump and I said you're not pulling the tank
and doing all this work. Pump was around $50.00. Hal
