Tractor Talk Discussion Forum
JD 175 FEL Bucket only works with low flow
RoyJr
02-01-2008 05:08:15
My JD175 fel bucket will only tilt up with the valve barely open or at engine idle. If the spool is opened all the way or the throttle is advanced, it stops suddenly, with a jolt. Goes down smoothly, lift works fine in both directions. No visible external leaks.
Controller is a double spool. I switched sides and the lift works fine on either side, tilt fails on either side. I took the tilt cylinders to JD dealer who repacked them. Not only did not help, now it leaks down. Help?
Tx Jim
02-01-2008 09:48:46
 Re: JD 175 FEL Bucket only works with low flow in reply to Lanse, 02-01-2008 05:08:15
Roy does it act the same with full and empty bucket? Jim
Bob
02-01-2008 07:11:02
 Re: JD 175 FEL Bucket only works with low flow in reply to RoyJr, 02-01-2008 05:08:15
Is there a pair of hydraulic quick-couplers involved in the "tilt" circuit?
If so, likely there is a problem with one of them, in that the ball is being lifted just barely off of it's seat, and gets slammed closed by high oil flow rates.
RobMD
02-01-2008 13:43:59
 Additional evidence to support Bob's theory in reply to Bob, 02-01-2008 07:11:02
A 4020 with a 158 loader had a condition where the loader would jump going up, but not down. The bucket hydraulics were fine.
So, we Scratched the broken spring in the pump idea.
A look at the quick connect for the "up" side of the loader showed broken internal parts. The ball was rattling around inside the socket.
RoyJr
02-01-2008 07:18:01
 Re: JD 175 FEL Bucket only works with low flow in reply to Bob, 02-01-2008 07:11:02
Yes. It does have quick connects. Thanks.
jonjon
02-01-2008 06:56:34
Id say bad releif valve. works when it dont have much pressure then to much releif opens dummps fluid.
RoyJr
02-01-2008 07:02:39
 Re: JD 175 FEL Bucket only works with low flow in reply to jonjon, 02-01-2008 06:56:34
Thanks. Where is the relief valve?
jonjon
02-01-2008 08:07:37
 Re: JD 175 FEL Bucket only works with low flow in reply to RoyJr, 02-01-2008 07:02:39
generally on the pump. Need a manual or at leas a parts breakdown from the dealership as I am not real familiar with this machine
buickanddeere
02-01-2008 18:20:39
 relief valve on the pump??? Re: JD 175 FEL Bucket only works in reply to jonjon, 02-01-2008 08:07:37
JD does not use a relief valve on the pumps with closed center hydraulics. Why would they when the pump de-strokes when system pressure reaches rated psi? I have seen pressure relief valves on loaders or backhoes to protect lines & rams from overpressure due to mechanical force.
albin
02-01-2008 08:14:27
 Re: JD 175 FEL Bucket only works with low flow in reply to jonjon, 02-01-2008 08:07:37
what tractor is this loader on
RoyJr
02-01-2008 09:23:30
 Re: JD 175 FEL Bucket only works with low flow in reply to albin, 02-01-2008 08:14:27
2640 but all other hydraulics work fine
jonjon
02-01-2008 10:01:22
 Re: JD 175 FEL Bucket only works with low flow in reply to RoyJr, 02-01-2008 09:23:30
I agree with Bob to check the quick couplers. This does have a open hydraulics system so there should be a regenerative valve and it has a bypass on it. BUT this is something I know little about, have seen them apart has a orfice,ball and solenoid involved but that is the extent of my knowledge of that.
RoyJr
02-01-2008 17:29:07
 Re: JD 175 FEL Bucket only works with low flow in reply to jonjon, 02-01-2008 10:01:22
It was the quick coupler.
Thanks guys!
