Tractor Talk Discussion Forum
BobCat 310
Tominnebr
02-10-2008 07:57:30
Working on an old Bobcat 310. Anyone know where to check Hyd fluid level? There is a filler plug just in front of the seat but I can't find where to check it. Also, is Universal Hyd oil okay to use? Thanks
Mark in Monroe
02-12-2008 00:31:06
 Re: BobCat 310 in reply to Tominnebr, 02-10-2008 07:57:30
Hey Tominnebr, I looked at my operators manual and found out that the oil level is checked by pulling out plugs on the lower area in between the vehicle drive wheels(right side). The plugs are offset - one is higher than the other,so you get the "High" and "Low" level. Be sure the machine is on level ground. The manual calls for Bobcat P/N#6563328 Hydraulic/Hydrastatic trans oil or 10w30 or 10w40 motor oil w/ "SE" rating. It takes 8 gals. total,but they say to fill to the "High" level hole. I think the Universal Hyd. oil will work. Be sure to change the filter,too.
Mark in Monroe
02-10-2008 22:33:30
Hey Tominnebr, I have a 310,but don"t remember where to check the oil level. I"m at work now and will check my service manual in the morning.
