Tractor Talk Discussion Forum
PTO shafts- best way to straighten?
jose bagge
02-12-2008 16:44:44
What's the best way to straighten the driveshaft for my PTO driven Post Hole digger? Lent it to a "friend", got it back bent like a "U". I straightened it in my press, and it doesn't spin too badly- but it binds as it increases or decreases in length so much that my digger ain't diggin'! This is one that has the cloverleaf shaped solid inside shaft.
Any ideas, other than get a new one?
ole/Mn
02-12-2008 18:25:18
 Re: PTO shafts- best way to straighten? in reply to jose bagge, 02-12-2008 16:44:44
Better to buy one now, before you pull the shaft out of the tractor, oops, did I just tell on myself? you can learn from my education tuition free
Jim B. in OH
02-12-2008 17:50:54
Better yet, let your "friend" buy a new one. I just got a 48" one w/guard for $116 at the local JD dealer. BTW half of what TSC wanted for the identical one. Jim
Larry D.
02-12-2008 16:55:29
Yep! You Answered your own Question, As I had One Bent on a Bush Hog and You are a WHOLE lot better off to get a new One. Mine (For the Hog) wasn't too Exp. Think around 80$ at TR Supply, I'm Thinking thats correct.. Larry KF4LKU
Larry D.
02-12-2008 16:55:01
Yep You Answered your own Question, As I had One Bent on a Bush Hog and You are a Whole lot better off to get a new One. Mine For the Hog wasn't too Exp. Think around 80$ at TR Supply, I'm Thinking thats correct.. Larry KF4LKU
Larry D.
02-12-2008 16:53:22
Yep! You Answered your own Question, As I had One Bent on a Bush Hog and You are a Whole lot better off to get a new One. Mine For the Hog wasn't too Exp. Think around 80$ at TR Supply, I'm Thinking thats correct.. Larry KF4LKU
Larry D.
02-12-2008 16:53:02
Larry D.
02-12-2008 16:52:36
Yep! You Answered your own Question, As I had One Bent on a Bush Hog and You are a Whole lot better off to get a new One. Mine (For the Hog) wasn't too Exp. Think around 80$ at TR Supply, I'm Thinking thats correct.. Larry KF4LKU
Gene Dotson
02-12-2008 16:52:00
You will not go wrong to buy a new one. It is nearly impossible to properly straighten one. Once they are bent, they have been weakened and will surely cause problems later... Gene
Larry D.
02-12-2008 16:51:25
Larry D.
02-12-2008 16:50:58
