Tractor Talk Discussion Forum
crankshaft
mark3006
02-18-2008 10:18:10
can anybody tell me original crankshaft journal size on my 1942 h tractor s/n 114195, std size bearings are loose the connecting rod has way to much play.i need a starting place to find out how much has been turned down.
El Toro
02-18-2008 11:44:51
 Re: crankshaft in reply to mark3006, 02-18-2008 10:18:10
You should pull tha crank and have it measured at your local auto machine shop. It may need to be ground undersize and they can supply the correct bearings. Hal
ejr-IA
02-18-2008 10:36:31
Rod 2.2475 to 2.2485 Mains 2.4975 to 2.4985 these are the standard measurements.
jonjon
02-18-2008 10:23:52
Generally when machine shops grind cranks they stamp how much over on the crank.
Allan In NE
02-18-2008 10:20:34
Look on the back of one of the inserts. Undersize should be stamped there.
Allan
BLinWMi
02-18-2008 15:53:41
 Re: crankshaft in reply to Allan In NE, 02-18-2008 10:20:34
Did IH have insert type rods in '42? I am not familiar with IH but know Deere did not have insert type rod bearings until the 60 came out in '54. Of course the babbit rods could be replaced in the older A's with the insert type.
