Tractor Talk Discussion Forum
compressor question
r vessar
02-18-2008 15:46:50
I have a quincey compressor model QT5 that has a bad rod that damaged the crank so had it turned but found out i cant get under sized rods or bearings and cant get blanks rods to bore the size i need any ideas.
Leland
02-18-2008 20:07:44
 Re: compressor question in reply to r vessar, 02-18-2008 15:46:50
order a new rod from quincy and take it to your machinist and let him rework it .
Den N Ms
02-18-2008 19:10:30
If you can get a standard rod,Take and file the rod and the cap.Try to File each piece the same amount.Fitting it to your crankshaft.Get you some plastic gauge and set the clearance.0015-002 Thousands.With the cap bolts torqued.
