Tractor Talk Discussion Forum
Stoutest rear axle
Roy Suomi
03-16-2008 19:02:04
I'm going to mount a forklift mast to the rear of a farm tractor..What would be a good candidate to do this to?? Gotta be cheap , plentiful and stout enough to handle loading dozer tracks onto trucks / trailers..I realize I'll have to counterweight the front of the tractor so we're not doin' wheelies when picking up tracks..
JoshuaGA
03-17-2008 19:48:08
 Re: Stoutest rear axle in reply to Roy Suomi, 03-16-2008 19:02:04
Two pieces of advice. #1. Check load ration on the tires. If one goes oh $#!^!!! #2. Don't weigh a tractor to the ground and then lift something. If the transmission castings are weak, and they break, to say the least you will own a tractor that can be in two places at once. I secont the recomendation for a proper forklift. Good used $5000-$10000 #5000 to #10000 capacity Offroad forklifts can be had around her if you look.
JoshuaGA
Bill(Wis)
03-17-2008 17:26:04
WC and WD Allis are good candidates for that. Many have been done up that way. Even done at the factory for a while (I think). JMS/.MN has at least one like that although he didn't mention it in his post below.
TractormanNC
03-17-2008 04:51:13
No one has mentioned this yet but something to think about. A friend of mine has done just this to a Ford tractor. He now has only one speed forward (reverse) and four speeds in backwards (the four normal forward gears). You might think about getting a Farmall H or M (maybe others) and flipping the ring gear over. This would give you five speeds for your "new" forward direction.
low budget
03-17-2008 04:44:07
A JD 5020 is STOUT. Cheap too. Probably a bit too bulky though.
JDknut
03-17-2008 04:14:36
IH 706 and 806 were built "hell for stout". IH was smarting from the 560 debacle so when they engineered the follow-on for the 560, they did it right for a change and made them extra heavy.
RobMD
03-16-2008 20:23:59
I'd think it'd be cheaper + easier to find an old forklift?
dhermesc
03-17-2008 05:22:42
 Re: Stoutest rear axle in reply to RobMD, 03-16-2008 20:23:59
"I'd think it'd be cheaper + easier to find an old forklift?"
Agreed
RodInNS
03-16-2008 20:04:30
Ford 5000, and go forward from there. The 4000 is pretty stout too but you'll need more weight on the steering axle....
From what I've seen, Ford's of that vintage and onwards had some of the heaviest axles ever built in that power class.
Rod
135 Fan
03-16-2008 19:47:55
I think a lot of the Massey forklifts used the same rear end as the farm tractors with a couple extra braces for the mast. A 65, 165, 175 etc.. Could also check what holds up on pulling tractors. Dave
Janicholson
03-16-2008 21:00:45
 Re: Stoutest rear axle in reply to 135 Fan, 03-16-2008 19:47:55
A neighbor of mine when I lived in Northern Ohio (Merle Grimm)
Ran a Massey 44 axle in all wt classes with about 5000 HP. (2-502 inch big block Chevys, one with a 8-71 blower, and one with two turbos. Tractor was called Sassy Massey. I vote for that axle. JimN
Mike M
03-17-2008 08:00:02
 Re: Stoutest rear axle in reply to Janicholson, 03-16-2008 21:00:45
In that case old Cockshutt rear ends used to be the choice for pullers.
I'm in agreement with the others. should be able to find a forklift allready set up reasonable.
JMS/.MN
03-16-2008 21:25:31
Roy wants to know about weight (lift and carry) capacity- to load heavy stuff. Certainly not the same issue as torque and tractor pulling.
135 Fan
03-16-2008 21:29:34
 Re: Stoutest rear axle in reply to JMS/.MN, 03-16-2008 21:25:31
I think they'd be related. Tractor pulling puts a lot of weight on the axle and is a real torture test on it. Dave
