Tractor Talk Discussion Forum
Vickers Power Steering pump repair parts?
T.R.K.
03-31-2008 17:53:13
The pump is on a Minneapolis Moline industrial tractor. Does anyone know if parts are still available or a source for parts for Vickers hydraulic pumps?
Thanks!
Kelvin
greygoat
04-01-2008 08:42:07
 Re: Vickers Power Steering pump repair parts? in reply to T.R.K., 03-31-2008 17:53:13
The model number is on a flat ground area, usually
on the rear cover of the pump. It"s very long, because it tells model #, flow, pressure, in a code.If you can find it,(it might be painted over)
e-mail me, and i"ll send you a parts print. I have a master parts book. most parts available,
but repair-ability depend on condition of pump.
NCWayne
04-01-2008 06:04:44
Found these guys the other day while looking for parts for a friends backhoe. I"ve never dealt with them other than calling about the parts I needed. Even so they are a Vickers dealer and can probably get you the parts you need or find a replacement pump.
J Schwiebert
04-01-2008 02:23:50
That is kind of a loaded question. Vickers is still very much in business however they are now part of the Eaton Group. Now you need to have the model number of the pump. Not all Vickers pumps have parts available anymore. I also sent you an e-mail. A friend of mine had a Vickers power steering pump rebuilt for a customer $400. for a different color tractor. You may be better off money wise by replacing with another newer pump with the same GPM and pressure capability if looks are not 100% important. I also sent you an e-mail. I used to have some contact with Am-dymic when we had the Gresen school. They do cylinders and the rest as well or did at that time. J.
guido
03-31-2008 19:03:56
Hello T.R.K.
Vickers pumps are used in the trucking industry.
Any truck delear or truck parts supplier will carry repair parts for them.The seals and pump vanes come in a kit,the pressure valve may come as a single part #. Very easy to take apart and repair.
Guido.
Gun guru
03-31-2008 18:02:54
There are a few companies in the Detroit area that sell rebuilt hydraulic Vickers pumps. 1. Western/Starr Warren, Mich or Fraser Mich. 2. AM-Dynic fluid power, Chesterfield Twp. Mich. (this place may only sell cylinders) 3. Paragon Technologies. Warren or surrounding area of Macomb county Mich. Good luck.
