Tractor Talk Discussion Forum
Deutz 10006
ewilvers
04-16-2008 18:34:44
Just bought a Deutz 10006 at an action do they have a temperature gauge or light and if so where is the sender what is their normal operating temp.
Norberg
06-22-2008 19:18:21
 Re: Deutz 10006 in reply to ewilvers, 04-16-2008 18:34:44
Almost all of the 06 series tractors have a temp. sensor mounted to the last cylinder-head that is wired to the horn. This is also true of the oil-sending unit. If temp. gets to hot or oil-pressure drops below so many pounds, the horn sounds. This is also explained in the owner's manual.
Donfarm2004
04-17-2008 20:51:34
Yes they have a gauge. Sending unit screws into one of the heads.
farmer boy
04-17-2008 05:26:57
Not sure what happened there. Sorry about that.
farmer boy
04-16-2008 19:58:35
Those tractors should have a gauge on the dash. Should be a simple one with no numbers. Also runs fairly cool according to the gauge. You won't get uo more than about 1/2 inch on the gauge. In my experience anyways.
farmer boy
04-16-2008 19:57:33
farmer boy
04-16-2008 19:56:47
Sam#3
04-16-2008 19:41:36
My brother had two Deutz tractors, models 'D60 06 and DX 110' and neither had a temperature gauge. It is necessary to kept the airway and fins clean.
r whis
04-16-2008 18:52:58
their air cooled,no gauge
old art
04-16-2008 19:23:09
 Re: Deutz 10006 in reply to r whis, 04-16-2008 18:52:58
air cooled still needs a temp. guage they can over heat and destroy tha pistons. the fuel air raito is important on them lean fuel mix will get hotter and burn valves.
