Tractor Talk Discussion Forum
shed roof
Iowa Ron
04-24-2008 13:03:31
Ihave a machine shed built in the mid 60s they used alumanum corrigated sheets [very simalar to the roofing used now] they installed several fiberglass panels for lighting ,they have began to rot away ....i dont have any sheets to replace them with. what should i do to cover over them,and be water tight??
higgins
04-25-2008 13:24:39
 Re: shed roof in reply to Iowa Ron, 04-24-2008 13:03:31
I would think the roofing plants could fabricate from a pattern.
Portland, TN has/had several of these little plants that made roofing in one long stream and they would cut it to the length you requested. I know they did fiberglass too.
steamnjn23
04-24-2008 13:26:49
Home Depot usually carries the see-thru sheets. maybe your local home centers can help with replacing them
Iowa Ron
04-24-2008 13:10:22
corrigation is way off ,have tried to fudge a piece of steel ..... ....big gaps
rhouston
04-24-2008 13:18:36
 Re: shed roof in reply to Iowa Ron, 04-24-2008 13:10:22
Could you remove a couple of sections on an end to replace the skylight sections then use newer stuff to replace the area removed?
JMS/.MN
04-24-2008 13:07:49
A lot of current sheets have a different "profile" than older ones, but you can fudge a bit with the foam insulation strips and maybe add silicone sealant.
