Tractor Talk Discussion Forum
540 rpm pto pumps
Scott in SF
05-17-2008 10:05:38
Can these things be rebuilt ? Is it worth it our should I just buy a new one ? The F 11 loader on my Farmall M is getting kinda weak.
Roy Suomi
05-17-2008 17:35:11
 Re: 540 rpm pto pumps in reply to Scott in SF, 05-17-2008 10:05:38
Only a flowmeter test will show how efficient a pump is..They will tell gallons per minute at a specified pressure..Low readings will indicate worn pump or plugged suction screen in the reservoir..If no flowmeter is available , check for a suction screen problem....If no problem there disassenble the pump...Mark the 3 or more sections of the pump with a center punch so it will be assembled correctly..If it's not put together right, the rotation of the pump can be reversed...Worn areas where the gears come into contact with the center section will indicate worn bushings or bearings..There are specifications for pump wear..I think 8 to 10 thousandths wear is borderline worn out...If so , get another pump
