Tractor Talk Discussion Forum
OT - Truck problem Dodge 360
David from Kans
05-20-2008 07:01:33
My engine is making oil. Problem started with oil gauge acting irratically. Had about 1 gallon excess oil in crankcase. Drained most out, adding about a qt of new oil. Drove 40 miles, now again is about a qt overfull. How can this happen and engine still runs excellent? Anyone had a problem like this.
Don L C
05-20-2008 07:27:34
 Re: OT - Truck problem Dodge 360 in reply to David from Kansas, 05-20-2008 07:01:33
David ---
You didn't say if the oil you drained ,had a strange smell.....how old is your truck? is it fuel injected or carb.?
I think your problem is gas getting into the oil pan....if you have a fuel pump, it can be leaking gas into the oil.....
If fuel injected, I don't know ...but I think its gas.....If it was water you would have seen it ( a gallon.).....
some one on here will know..... my info.is old good luck Don
Allan In NE
05-20-2008 07:19:06
Fuel pump, choke pull-off, saturated float.
Just tryin' to help ya think here.
Allan
PJBROWN VT
05-20-2008 07:15:35
Is the head gasket starting to go bad? Is your coolent low?
PJBROWN VT
05-20-2008 07:13:05
bradk
05-20-2008 07:07:18
IF it's and older 360 with carburetor,the fuel pump is bad and leakin' gas into engine.
David from Kansas
05-20-2008 07:22:55
 Re: OT - Truck problem Dodge 360 in reply to bradk, 05-20-2008 07:07:18
OK, thanks guys. I should have said it is a 2000 model, fuel injected and there is no coolant in the crankcase and the cooling system is full. I'm thinking it has to be gas, but what i don't understand is how it can be getting into the crankcase. If there is a bad injector, wouldn't it be missing; running rough?
Vern-MI
05-20-2008 12:26:22
 Re: OT - Truck problem Dodge 360 in reply to David from Kansas, 05-20-2008 07:22:55
Leaky injector so connect a pressure gage to the fuel rail and watch for pressure fall off when the engine is shut down. It isn't leaking bad enough to cause rough running yet. You may be able to find it by checking for particular cylinder missfires during startup or by pulling the plugs and looking for a cylinder running richer than the rest.
RusselAZ1
05-20-2008 18:58:26
 Re: OT - Truck problem Dodge 360 in reply to Vern-MI, 05-20-2008 12:26:22
Agree Vern. If it is gasoline getting into the oil it has to be coming through one or more injectors. Everything else is at the fuel tank.
GregCO
05-20-2008 08:10:05
Fuel pressure regulator?
Greg
